Non adjustable rockers
Old Dec 26, 2010 | 01:28 PM
73 ford guy's Avatar
73 ford guy
Anybody have issues with getting good oil supply to top rocker shaft on their fe. My one side rockers have good oil flow to shaft and down the top of pushrod while preoiling but otherside only gets oil to top shaft without dripping down pushrods. Motor is fresh and just broken in now but it has a tick from the side I think was not flowing ideal. I swapped 2 other stock rockers I had laying around and they all did the same thing . Only the one set oils proper and it doesn't matter if I swapped sides.. Any hints on a fix??
Old Dec 26, 2010 | 01:37 PM
ford390gashog's Avatar
ford390gashog
You have a restricted oil passage in the head. Did you install any restrictors? Are you using the correct tapered bolt in the right hole?
Old Dec 26, 2010 | 02:00 PM
impish's Avatar
impish
I could be wrong, but seems like the rocker hold-down bolt securing the one through which oil feeds upward to the shaft is a BIT longer than the others, too.
Old Dec 26, 2010 | 02:22 PM
Bear 45/70's Avatar
Bear 45/70
It is shanked (smaller diameter in the the middle) so the oil can get past the bolt and if the bolt in that hole is a regular bolt you will get what you are getting. Check the bolts on the low oil rocker.
Old Dec 26, 2010 | 02:51 PM
73 ford guy
Yes I have restrictors. Yes I have the right bolts in proper locations. Even with the restrictor removed I couldn't get the one rocker to oil proper. Oil would go up into shaft but not down pushrod like I said. I tried 2 other rockers kicking around with again no luck.
Old Dec 26, 2010 | 03:07 PM
Bear 45/70's Avatar
Bear 45/70
Then you either have a cam bearing installed wrong and/or the head gasket.
Old Dec 26, 2010 | 03:16 PM
73 ford guy
Yeah but I an swap the good rocker from either side and it works like it should with or without restrictors.
Old Dec 26, 2010 | 03:22 PM
Bear 45/70's Avatar
Bear 45/70
I need to read closer. You can have the rocker shaft mounted backwards in the stands and cause this. Then the holes doe the oil to the rockers don't line up right.
Old Dec 26, 2010 | 04:13 PM
73 ford guy
I messed around with it for a good 2 hours. I took a couple sets of rockers apart and checked the line up holes. I found my good rockers had the hole elongated from just a simple hole. I die grinded the other bad one to the same as the good one with not much better success other than just seeing oil under the rocker pivot arm but again no drip down pushrod. I called it quits after just not getting a good 100% fix. It was just ok
Old Dec 26, 2010 | 04:16 PM
73 ford guy
I have 4 rockers in total , 1 is the one that works well. The other 3 act all the same with no drip down pushrod. It would seem weird if all 3 of these would be backwards with me never having them apart before... Weird
I have all the shaft oil holes facing down.
I'm assuming the tick noise is from lack of lubrication on that rocker as the noise comes from that side of rocker I knew wasn't 100% after install. The tick gets less under throttle increase and is worse at idle.
I don't think it can cause too much of a worry for damage other than just the pushrods themselves which are an easy replacement.. Is this the regular tick/ knock noise in an fe?
Old Dec 26, 2010 | 10:05 PM
OrangeJuice's Avatar
OrangeJuice
Could an oil passage hole in the rocker shaft maybe be plugged with crud? Before I put my assembly back together I hit the oil passages with some air to clear them out. I knew they were clear when it sprayed a bunch of oil on me...lol.
OJ
IHguy
18
Nov 24, 2017 09:11 PM
Montync
16
Apr 3, 2016 01:55 PM
Roger C
Jan 14, 2016 10:02 AM
Capt'n Phillips
Washington Chapter
15
Nov 15, 2013 12:23 PM
