traction question e4od
Old Dec 26, 2010 | 07:47 AM
fixitman1310's Avatar
fixitman1310
hey guys i have a 97 f350 powerstroke 265,000. this truck was an
ambulance before i bought it. will this truck have positive traction
rear end. how can i find out? thanks for any help.
steve n.carolina
Old Dec 26, 2010 | 08:16 AM
Brown Falcon's Avatar
Brown Falcon
It should say on the rear axle tag. Look for the code and that will tell you the gearing and whether it had Limited SLip or not.
Old Dec 26, 2010 | 11:20 AM
redman84's Avatar
redman84
Look at the tag in the drivers door jamb. If it has a letter and number then you have limited slip. If it is a two digit number then you have unlimited slip. Either of those are both considering that no one has changed them. I got've an axle code link somewhere but am workin from phone so I cant access now. If you look on the axle tag likes even said then you should be able to identify 4.10 vs 3.55 . Also if you jack up the rear and spin a tire and they both spin then you have LS
Old Dec 28, 2010 | 07:47 PM
fixitman1310
thanx alot for the info
