Cat/DPF SCT :)
Here are the details on my f450. 20k miles in emmaculate condition. All dealer service records were kept by the previous owner. I also got the Ford Lincoln Mercury premium care warranty transferred to me for $40.00 after my purchase of the truck. When I went to my local ford dealer here to get it transfered into my name, the service manager said I got the best warranty that ford offers, he chuckled and said I got it for $40 bucks. Now to the rest of the story.
I immediatly put a CM flat bed on the truck because that is what I use in my line of work. really pleased with the fit and looks of it on the ford (I had one on my dodge truck as well).
After reading through the forums, I realized my needs in a vehicle are not what the DPF system allows. I idle sometimes for a couple of hours or more each day at different job sites of my mine. So I decided to remove the Cat and DPF and get a tuner. I found a SCT livewire Extreme (used) in SanAntonio on friday, he had the Cat/DPF pipe and tuner for $400. I pulled the Cat/DPF last night, and I installed the canned "performance tune" today after doing a few hours of reading because my tuner did not come with any directions. All he sold me was the tuner/pc cable/wire to obd2, no paper work or instructions. I was tenative because I had no written instructions and could not find any on the SCT site through a pdf file ect. The tuner worked flawlessly and I left my stock muffler on for the time being. My truck at idle sounds like a smooth (not loud at all) jet engine at the exhaust. It actually smells like its burning deisel now! When i smelled and heard it this afternoon after I cranked it up the first time, it reminded of my Caterpillar D9
.Im not a hot-rod, this is not the reason I did the modifications, I wanted better fuel milage and the ability to idle for hours if needed. I rarely drive over 55 and have a very light foot around town. I carry way to many tools and other stuff on my flat bed to be hot-roding around, I would be slinging stuff all over texas.
Lastly,
1. I wanted to get some opinons on a K&N filter. I already ordered one and the dry cover for it as well, but I work in some very dusty conditions during the summer months and I am a bit concerned about the filtration abilities of a open air/oiled filter. Do any of you have any input on wether or not I should or should not install the K&N?
2. For those who are familiar with the SCT livewire, can I plug my tuner back up to the obd2 port again, and turn off door chimes or add my cold air intake when my K&N filter arrives or do any other changes WITHOUT HAVING TO RETURN TO STOCK and doing the entire procedure all over again?
Thanks guys, I enjoy the forum.
GODSDOZER
the extreme also has support for an exhaust gas temp probe, which is optional.. did u get that?
I was trying to buy a used SCT myself this fall, but the seller just stopped answering email. I bought a used sensor kit, and don't need it.
I am up near austin. You have to drill a hole in the exhaust pipe to screw in the sensor.. (the Spartan setup uses the stock sensors)
as u don't have 25 posts you can't email or private message someone (FTE rules to prevent automated spam).. my direct email is my FTE username at gmail
see the posts by texas450 for his experience with the SCT in a 450, think he is getting around 13.5 with a flatbed load.
https://www.ford-trucks.com/forums/9...ml#post9246098
Sam
Sam
. I would really like to keep my truck as stock as possible, so in the event that I have to take it in for warranty repairs I will not have to spend 2 days ect. returning it back to stock form.As per the exhuast temp probe, I just used my regular probes as well. As I understand it, the sct uses the stock sensors.
Can yall give me some Ideas: Since all I have read about MPG increases, it is my understanding that the higher the tune used the better the fuel milage you will get provided that you stay off the throttle.
I was thinking about changing my canned tune from the "performance" canned tune to the "extreme" canned tune.
1. Do you know the horsepower difference between the performance tune, and the extreme tune?
2. Do you know if there are any engine stress problems associated with using the extreme tune. *** I will remind all agian, I drive like a grandmaw, so its not about Hot Roding.
Godsdozer
Godsdozer
1. "alot of money" is a relative term, to some it may be alot, to others it may not be.
2. You may have missed my orgional post............I said, I did it mainly because of my considerable amount of Idleing at my job sites. I do not need a DPF clogging up on me (causing downtime in the repair shop) or burning excesss fuel while in regen.
3. Since I removed the DPF, I had to get a tuner.
I keep my work trucks for 200k miles. It takes to much money and time to put new flat beds on them, and get all my equipment I haul on the flat bed off and transfer to a new truck every 50k or 100k miles. I carry about 4-5k lbs or more on my flat bed each and every day as a daily driver. If I only gain 2-3 mpg, in the long run it will certainly pay for the $400 total I have invested in the DPF/Cat delete pipe and Sct livewire tuner.
I had looked at the axle sticker a couple of weeks ago, I figured the 4L stood for 4.10, thanks for the clarification.
Godsdozer
https://www.ford-trucks.com/forums/4...ml#post3792342
Sam
Mine is a 250 4x4 CCLB with 3.55's gears.
Godsdozer
