Sponsored by: Real Truck
33x12,5x17
Old Dec 24, 2010 | 11:18 AM
preco's Avatar
preco
33x12,5x17
hi any body know if i can fit 33x12,5x17 tires on my 17 inch rims and does it clear the chassis and body and finaly does it impact on my milage i dont know what gears i have i the differentials so it maby are to big and slugg acceleration if you have any suggestions please send a reply and regards from sweden and by the way i forgot its a 2005 super duty 6,0 with original wheels
Old Dec 24, 2010 | 12:23 PM
stuffdeer's Avatar
stuffdeer
I had a 2007 and put 35x13x20 on it and there was very little or no rubbing. Gas milage went down...
Old Dec 24, 2010 | 12:36 PM
Furian's Avatar
Furian
You Keep What You Kill
Hi Peter,
I'm running 33X11.5R18 on my 2005 F350 with stock suspension with no issues at all. Assuming your truck has the coil spring front suspension, you will be fine with the 33X12.5R17 tires.
Is this your truck?
Old Dec 24, 2010 | 05:23 PM
redford's Avatar
redford
FTE Leadership Emeritus
You may have problems finding a tire shop that will mount 33X12.5 on stock rims. 285 is generally the widest you want to prudently put on stock rims.
Yes
Yes, your mileage will go down any time you run a wider tire and put your truck up higher.
Old Dec 24, 2010 | 06:07 PM
preco's Avatar
preco
yes its my truck
Originally Posted by Furian
Hi Peter,
Is this your truck?
it have coils in front + 2 more leafs in rear + firestone airide the reason why i ask is it seems to be impossible to get 31 inch tires for 17 inch rims so i guess it must be 285x70x17
Old Dec 24, 2010 | 06:25 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I had a set of 12.5" tires on 9" rims and still had tread wear issues with the tires being too wide for air pressure to correct for. Now with 295s on 8" rims I run 55psi instead of the sidewall max of 80 and it's almost perfect out back. You'll kill a set of 50,000 mile tires in 20k flat because the center of the tire will wear to the bars before the outer lugs are half gone.
265/70/17s work out to 31.6x10.5. A 285/70/17 is 32.7x11.
Old Dec 24, 2010 | 06:40 PM
bayou barataria's Avatar
bayou barataria
If your tires are wearing more in the center they are probably overinflated.
Old Dec 24, 2010 | 10:02 PM
texastech_diesel
Token Redneck
Or they're E-rated tires running 35 PSI instead of 80 on wheels that are too narrow. No amount of air pressure adjustment can account for a rim that is narrower than the recommended range, the belts won't flex enough to flatten out the tread block unless you air down to a pressure that isn't safe to drive on. Drop an e-rated tire to 30PSI and feel how much delay there is in the steering, the sidewalls flex before the tread block moves, and the steering feels like mush.
I ran D-rated 35x12.50s on a 9" wide rim, aired down from 55 to 25 and they still weren't anywhere near flattened out. Not enough weight on the rear axle. The fronts had to go down to 35 before they were decent, and that's with the extra weight of the diesel pushing down on them. 10" rim would have been a lot better, a rim more than 3" different from the tire's section width will cause wear issues regardeless of air pressure. The OP wants to run a 12.5" wide tire on a 7.5" wide rim, ain't no way a 5" difference is going to work.
Old Dec 25, 2010 | 07:49 AM
Furian's Avatar
Furian
I never had understood why Ford uses narrow OEM wheels on the Super Duties... I guess it is just a cost issue for them.
Old Dec 25, 2010 | 08:31 AM
redford's Avatar
redford
I would like to go a little narrower on the tires and wheels, if I could. The narrow footprint works better in snow.
Old Dec 25, 2010 | 08:37 AM
Furian's Avatar
Furian
Understood... but I think that you are in the minority.
L. Horton
13
Feb 6, 2017 09:23 PM
302Fanatic
Nov 24, 2016 09:59 AM
Robert Lee Gill
Nov 14, 2015 06:13 PM
dave3406
1978 - 1996 Big Bronco
Sep 30, 2013 02:41 AM
MADFord4X4
15
Sep 7, 2011 04:55 PM
