Dana 60 rear disc brake conversion
#33
#34
I have read that you need to get a new proportioning valve that is set up to run disc/disc instead of disc/drum. They said the reason was that the drum brakes have residual pressure from the proportioning valve so they always have LIGHT pressure on them. I guess so the pads dont slam against the brake drum? Don't know if this is so, just what I heard, but 76HBoyNut it kind of sounds like if this is true your problem is the proportioning valve. You can get them for like $60 from Broncograveyard. Hope this helps.
#38
That and I wanted to do it right the first time. After reading this -
The Brake Bible
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
I was looking to do the hydroboost and redo the lines with stainless so I wouldn't have to touch them for at least another 30 years....but that was another $1k. So she's sat for nearly a year and a half. Also needs some tranny work...and I'd like to put in a Coyote crate motor with Tremec T-56 Magnum (more $$$)....so I've procrastinated resolving that problem as well. For the love of money....
#42
update.
In searching for some parts for running the lines on crew I came across the residual valves. I was right at 2 PSI & 10 PSI.
Links for valves in here.
Wilwood Products
2 PSI - disks
F911 Bolts Chrome Bolts, Stainless Steel Bolts, Metric Bolts, Socket Head Cap Screws, Grade 8 Bolts.
10 PSI - drums
*edit* just noticed the link titles are funky - but they all go to the right things.
Wilwood Products
2 PSI - disks
10 PSI - drums
fordboy_52
01-27-2016 06:21 AM
castone001
04-18-2009 01:13 AM
classyfish
16
02-12-2006 11:52 AM
starryrose
01-19-2002 10:13 AM
