I had extra intake springs laying around so I decided to get ride of the rotators and use the longer intake springs and intake retainers on the exhaust valves(E7 heads). Now that I have them on I notice that the install height on the exhaust valves are .100 inch shorter. How much will this effect the motor? Should I go back to using the rotators? I tested the springs and the original intakes were 110 lbs at install height. The ones I put on the exhaust were 108 lbs at the original install height. Now that they are compressed another .100 inch I would figure they are closer to 120 lbs now. The heads are off, so it would be easy to take them out and change over. Anything I am missing? Am I waisting my time trying to get rid of the rotators?
The rotators serve a useful purpose, which is to reduce the chances of valve burning, and equalize stem wear. So they are a good thing to have unless you are revving pretty high when their extra mass will cause the valves to float sooner.
If you drive over 5000 rpm a lot of the time and notice valve float then it might be good to delete them.
If I remember correctly, the retainer groove is in a different location on the exhaust valves versus the intakes to accomodate the rotator. TrickFlow makes a set of springs and retainers designed specifically for Ford heads to eliminate the rotators and give you stiffer springs. Is there a particular reason that you're trying to eliminate the rotators?
Thanks. I was just playing around. I had the parts and thought I would give it a try and reduce the mass of the rotators. So from the sounds of it, you guys think I should keep the rotators. So, do you think the .100 less install height the way they are now would make any difference?
