2011 5.0L F-150 mileage?
#76
Just got back from a 300 mile trip 150 there 150 back. On the way there traveling into about a 10 to 15mph head wind I got 16.9mpg with the cruz set at 70. filled back up now with a tail wind and same speed I got 18.2. Hand calculated mpg.
A little about the truck it is a supercrew FX4 6.5box and the truck has 800 miles on her now.
Very encouraging and thank you sir. We already know it has the 3.73 axle and 157" WB. I'm impressed.
#77
#78
Yes to every thing above. I believe that it will get better with some miles and once they switch back to summer gas I usually pick up a mile or two per gallon. I hope she will hit 20mpg but if not I still love this truck. The best truck I have ever owned.
#80
Wish Ford had kept the weight down to say the mid 90's level 3950 lbs. With these new engines, the mpg & acceleration figures would be outstanding.
#81
This becomes a point of controversy in the forums. Weight v. capability. While we all want awesome mpg's, what we're getting is a truck that gets mpg's that are competitive with the three other full size truck makers AND a truck that is more capable. It'll tow more and has the safety ratings as well.
And last but not least, she's beautiful, if I may be so biased.
#82
#83
#84
#86
Items such as multiple airbags, door side reinforcements, electronics & emissions equipment. Conversely though, use of aluminum engine blocks & heads should save some weight. Possibly, on the balance, the net weight savings are negligible as well as fuel economy where as capacity (cargo & passenger) has a higher payoff (greater value) to the customer.
#87
#88
My truck is a short bed standard cab with 5.0 and 3.55 lim slip-2 wheel drive. A little hot rod!
