6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L Block Heater
Old Dec 23, 2010 | 01:33 PM
mackda600's Avatar
mackda600
6.4L Block Heater
Bought my truck from Fl and it did not come with a blaock heater cord or element installed in the block.
I have since purchased both parts and plan to install myself.
HOWEVER, I have no idea where this goes into the block. I have spent a good deal of time on the phone with Ford techs and none of their diagrams are showing it clear enough.
Can anyone take a picture of their heater and where it is installed. All when i remove the plug to install the heater do i need to drain any fluids prior to this?
Old Dec 23, 2010 | 01:45 PM
powerstroke72's Avatar
powerstroke72
Moved to 6.4L Power Stroke Diesel forum.
Old Dec 23, 2010 | 02:26 PM
senix's Avatar
senix
Welcome aboard...1st thing to do is take the block heater back and get your money. All you need is the cord.
Did you verify that you don't have the cord first? Check on the passenger side. Right inside the bumper by the yellow latch for the hood. It would be a standard 110 plug there if you have it.
It rounds along the frame to just above the starter where it connects into the block.
Here is some pics:
Ford Truck Enthusiasts Forums - senix's Album: 6.4 block heater cord
Also this pic...# 28 is the cord and 27 is the element
Old Dec 23, 2010 | 02:30 PM
powerstroke72
Great post Scott! Tried to rep you but got the message.....catch you soon.
Old Dec 23, 2010 | 02:34 PM
senix's Avatar
senix
Thanks John! Have a good Christmas!
Scott
RuralSurvivalGuide's Avatar
RuralSurvivalGuide
Yea...it was my understanding that all 6.4s came with the heater, but warm areas did not come with a cord. I bought mine on ebay for $20, including shipping. Ford wanted $90 when I checked with them.
Old Dec 23, 2010 | 02:36 PM
senix's Avatar
senix
Let me also add that when plugging in all you need is about 3 hours before you fire it up. Unless it is really really cold.
Old Dec 23, 2010 | 02:59 PM
powerstroke72
Scott
Merry Christmas to you and the family as well Scott!
Old Dec 23, 2010 | 03:24 PM
tgreening's Avatar
tgreening
I thought this as well but....my truck was originally sold in southern TX and it had both already installed when I went there to pick it up. Point to the OP being, check before you spend the money. Luckily my service guy checked for me when I mentioned ordering one and saved me the hassle ordering something I didn't need.
Old Dec 23, 2010 | 03:57 PM
mackda600's Avatar
mackda600
alright just came in from looking it over. The element was right where you said it was SENIX. however the cord was a b***h to get in and i could only get the retaining nut hand tight as i couldnt even put any kind of tool up there to tighten it... hopefully it works!
THANKS FOR ALL YOUR HELP. MERRY CHRISTMAS TO ALL!!!
Old Dec 23, 2010 | 04:41 PM
senix's Avatar
senix
Should work, just keep an eye on it. When it warms up in the spring you can look it over real good.
Put the cord on a timer and then have it activate on its own.
Old Dec 24, 2010 | 12:29 PM
WhiteEx's Avatar
WhiteEx
Does anyone know what the amp draw of the block heater is? I was just shopping for a new timer and didn't know if I should get a 15 amp or 20 amp.
Thanks.
Old Dec 24, 2010 | 12:50 PM
senix's Avatar
senix
15 amp will do it. that is what I use.
Old Dec 24, 2010 | 01:00 PM
Tom's Avatar
Tom
Thanks.
According to KC8QVO it only draws 8.5 amps.
https://www.ford-trucks.com/forums/1...-wondered.html
I never got to measure the one on my '08, but my '11 draws only 900 watts, which corresponds to what KC8QVO measured on the '08.
Old Dec 24, 2010 | 02:07 PM
Bounds-Electric's Avatar
Bounds-Electric
FORD USER
Keep in mind how long of cord you use. (50' cord 14 gage or better) (over 50' cord 12 gage)
8.5 amps at 120 volts
9.27 amps at 110 volts
10.2 amps at 100 volts
The longer cord the more voltage drop
If you can get all 20 amp devices, Do not use light timers, With heat loads always go higher amp due to over heating,
