Injectors, how to get to them..
On the passenger side, getting to the valve cover bolts and oil rail bolts are a PITA for the ones next to the air-box.. How have other folks done it? I know for the valve cover bolts a speed wrech will do the job afer you remove the fendor trim.. However what tool are people using to get the T30 torx screw out with? Using a normal 1/4" ratchet with torx bit is too tall..
Please share..
Please share..
Please share..
Please share..
Amazon.com: Gear Wrench 9536 36 Piece Ratcheting Wrench Access Bit Set: Home Improvement
Here is a whole set or
Amazon.com: GearWrench 9535 Access ScrewDriver Bit Adapters, 2-Piece: Home Improvement
now perhaps i can find this locally.. not finding much on harbor's website, but of course they have awful descriptions
On the passengers side to get to the lower 2 valve cover and oil rail bolts. You have to remove the inner fender liner. Once that's out of the way you can slip a wrench on those bolts and loosen enough to get em out with your fingers. Hope it helps, I just changed out #3 on Saturday. Easy job just a PITA to get too. Good luck
