Sponsored by: Real Truck
no headlights
Old Dec 22, 2010 | 06:39 PM
erniek70's Avatar
erniek70
Question no headlights
I have a 2005 F250 with daytime running lights(DRLs). I have no lo, or hi-beams working, nor are my DRLs working. My foglights, and running lights, and tailights are working. I have found no blown fuses yet. The lo-beam fuses are not blown....have not checked for a DRL fuse yet. Any ideas, anyone
Old Dec 22, 2010 | 09:47 PM
erniek70's Avatar
erniek70
ok, so I have hi-beams only with manual headlights. I have no lo-beam ever, and no hi-beam with the auto headlights. Could it be a bad relay? A bad DRL module?
Old Dec 23, 2010 | 12:48 AM
JockD's Avatar
JockD
Are you sure that the low beam filaments are not burned out? You can use a test light to see if there is power at the bulb with (1) DRL on, (2) regular low beams on. If no power in position (1), then the DRL resistor may be burned out. If not power in positon (2), then the DRL relay may be bad, but to get the symptoms you describe, both the relay and resistor would be bad.
The low beams get power from two different places depending on DRL or regular low beams are selected.
Old Dec 23, 2010 | 06:44 AM
erniek70's Avatar
erniek70
I just find it odd they low beams would both burn out at the same time, and that the high-beams only work with the mamnual healdight switch (not auto).
I've found the relays (3) under the hood. Where is the resistor and/or module?
Old Dec 24, 2010 | 03:07 AM
JockD's Avatar
JockD
I'm not much help on the details, since I have an '01, which has a much different electrical system. The fact that the high beams still work with the headlight switch in manual indicates that the DRL relays or control module are probably the culprit.
Don't dismiss the burned out filiment possibility. Usually one burns out without you noticing, then when the other burns out you really do notice!
Old Dec 24, 2010 | 01:34 PM
erniek70's Avatar
erniek70
lights are brand new
on an '05, how do I unhook the DRLs? Just pull all 3 relays? Is there a module?
lights work now, after removing, and reinstalling the dash switch
Old Jan 3, 2011 | 05:03 AM
erniek70's Avatar
erniek70
removed switch, then re-installed. all lights worked for a bit, then low-beams stopped working again! DRLs are not working either.
Old Jan 3, 2011 | 05:45 PM
erniek70's Avatar
erniek70
could it be a bad auto-headlight module? I also pulled the 3 DRL relays under the hood (one at a time), and this did not seem to fix it.
It also seems the running/marker lights are staying on, even in the daylight. I will double check tomorrow though. The parking brake also seems to not affect the DRL function either.
Old Jan 3, 2011 | 07:09 PM
erniek70's Avatar
erniek70
Fixed it! Found a short in the old plow headlight wiring. Wrapped conduit & tape around the wiring. All is good!
TheSharkGuy
2015 - 2020 F150
Jan 6, 2017 03:31 PM
abranz
13
Sep 13, 2016 10:28 AM
AndrewZimmermann
Electrical Systems/Wiring
Sep 29, 2014 10:08 AM
matthewg
18
Jul 28, 2012 08:36 PM
DrewF
6.7L Power Stroke Diesel
31
May 11, 2012 08:40 AM
