how to replace headlight assembly in a 95 explorer?
Old Dec 22, 2010 | 05:22 PM
celjel's Avatar
celjel
My father has a 95 explorer in great shape but the headlights are yellowed badly. I bought him a new set and am wondering how big of a job it is to change them and if there are any neat tricks to help out. Any information on this would be greatly appreciated.
Thanks!
Old Dec 22, 2010 | 06:28 PM
ncranchero's Avatar
ncranchero
Parking, Turn and Front Side Marker Lamps, Explorer
Removal and Installation
Unlatch and swing radiator grille opening panel (8190) to left or right.
Remove screws attaching lamp assembly to radiator support (16138) .
Disconnect wiring.
Remove lamp assembly.
For installation, follow removal procedure in reverse order.
Headlamp Assembly, Explorer
Disconnect battery negative cable.
Remove blind rivets (2) attaching screws (4) and radiator upper sight shield.
Remove turn/park lamp attaching screws (2) and pull assembly away from body. Remove bulb sockets from housing and remove lamp assembly. Repeat on opposite side of vehicle.
With turn/park lamp assembly removed, screw attaching grille to front fender flange is accessible. Remove grille attaching screw. Repeat on opposite side of vehicle.
Remove attaching screws (4) located across top of grille.
Grip lower edge of grille and pull outward to disengage from retaining clips. Remove grille.
Using needle-nose pliers, compress barbs on headlamp housing retainer. With barbs compressed, pull forward on housing just enough to disengage from retainer. Repeat on opposite side of headlamp housing.
Turn headlamp housing as necessary and pull forward to disengage from headlamp aiming ball socket.
Disconnect wiring from headlamp bulb socket.
If replacing headlamp housing, remove retaining collar and bulb.
For installation, follow removal procedures in reverse order. Make sure to check headlamp aim.
Old Dec 23, 2010 | 04:22 AM
celjel's Avatar
celjel
Thanks for the help. We are going to attemp it sometime today.
Old Dec 23, 2010 | 04:51 AM
ncranchero's Avatar
ncranchero
It's not difficult but I added some info and a photo.
Old Dec 24, 2010 | 11:33 AM
celjel's Avatar
celjel
We finally got around to changing out the headlamp assembly. Using the instructions that you gave me made it a breeze. It took us less than 2 hours to complete the job! Thanks for your help.
Old Dec 24, 2010 | 11:41 AM
ncranchero's Avatar
ncranchero
Glad it went smooth!
dave91gt
2015 + Expedition & Navigator
16
Jan 23, 2017 06:00 AM
derekb
Jan 31, 2016 05:14 PM
geotracker91
Crossovers
May 1, 2013 09:52 PM
fishslayer14
Apr 10, 2011 04:42 AM
KevVer
Jan 24, 2010 03:43 PM
