Power steering fluid
Old Dec 22, 2010 | 04:54 PM
Awmjr05's Avatar
Awmjr05
Does anyone know which line on the resivor is the return line?
I'm trying to drain it out and put new in.
Old Dec 22, 2010 | 05:19 PM
rocky1074's Avatar
rocky1074
Not sure which line is return.Just want to add you might want to think about adding a filter to you PS. It's an in-line transmission filter but works great on the PS..I change mine once a year...Just my .02
(Magnefine # M010CB 3/8 lines)
, Inline transmission filters, Bulkpart transmission parts
Old Dec 22, 2010 | 05:31 PM
69cj's Avatar
69cj
It's the rubber hose on the top of the hydroboost unit. I used Mercon V synthetic 4 qts. I added app. 4 inches of hose to the boost unit and added the above mentioned Magnefine filter.
Old Dec 22, 2010 | 05:46 PM
rocky1074's Avatar
rocky1074
Hey cj can I use Mercon V synthetic on my 03 ???
The manual say Mercon ATF
Old Dec 22, 2010 | 05:51 PM
69cj's Avatar
69cj
Mercon V syn. is ATF. Yes you can.
Old Dec 22, 2010 | 05:55 PM
rocky1074's Avatar
rocky1074
Thank You
Old Dec 22, 2010 | 07:04 PM
Awmjr05's Avatar
Awmjr05
What's the easiest way to do drain it
Old Dec 22, 2010 | 07:57 PM
phoenixrhino2's Avatar
phoenixrhino2
Here is a link to a great write-up on the procedure;
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old Dec 22, 2010 | 08:04 PM
phoenixrhino2
The link below will show you some pics of my fluid flush Old vs. New. My truck had 45k at the time and not sure if previous owner ever flushed.. Doubt it..
Power Steering Flush Pics - Ford Powerstroke Diesel Forum
Old Dec 22, 2010 | 09:08 PM
rocky1074's Avatar
rocky1074
Thanks For Sharing
arkredneck
1978 - 1996 Big Bronco
Nov 24, 2015 02:11 PM
farmnaggie
Sep 23, 2014 08:36 PM
Scoop531
Sep 18, 2014 09:10 AM
RailDawg
Dec 19, 2009 12:02 PM
LIGOOMBA
Nov 10, 2008 08:39 PM
