Belt driven squaking noise? Video inside
Old Dec 24, 2010 | 12:00 AM
JJD's Avatar
JJD
Good luck nitro I've had the same problem. I've changed tensioner pulley no help. When i put on a new belt it will stop for a while but slowly returns. I even put extra pressure on the belt while running to see if it would make a difference but it made no difference. Temp and moisture made it squeak also until it warmed up. but eventully it does not stop. This all started when I thought my OEM belt looked a little dry rotted and cracked so I decided to change it with another OEM belt. No squeak before then but it's been a nightmare since. My water pump did go out I changed it and installed a new belt. Now it squeaks only when it's cold or it's been raining it will squeak at start up until it dries or warms up. Good luck hope you find a cure let us all know. I will clean my pulleys with brake cleaner and try that. ltl you put brake cleaner on your belt also???
Old Dec 24, 2010 | 12:07 AM
Skip1970's Avatar
Skip1970
how long these tensioners and idlers usually last?
Old Dec 24, 2010 | 02:10 AM
timmyboy76's Avatar
timmyboy76
Been pooring rain here, last 5 days, fired truck this morning, and no rain, but developed same squeek. Think the culprit on mine, is the "guide" pulley, up top, left of the alternator.
Old Dec 24, 2010 | 06:46 AM
jt371's Avatar
jt371
______
My belt makes noise depending on the temp. I removed the idlers, pressed out the bearings, removed the seals, cleaned, dried and regreased, reinstalled the seals, pressed back in. Same noise. I installed new idlers. Still same noise. I checked everything over and couls not find anything else wrong. It does go away when it dries out and warms up. I did notice that mine squeaks when the writing on the belt goes by the tensioner. Thought it was weird but I guess yours does it also. So must be the belt.
Old Dec 24, 2010 | 07:10 AM
429 f-100's Avatar
429 f-100
im gonna say 100000 since i have changed all three at once twice now and at 260000 she is quite now wes
Old Dec 24, 2010 | 02:30 PM
nookiemonster55's Avatar
nookiemonster55
Is it me or am I just seeing things? Notice everytime the white part of the belt comes by...squeak squeak squeak....I am thinking belt....
Old Dec 26, 2010 | 10:14 AM
jt371's Avatar
jt371
______
That is what I noticed on my truck. I know it sounds weird. I didn't say anything about it cause it seemed so weird. So I just left it alone. It only does it on occasion and only for a little bit if it does.
Old Dec 27, 2010 | 02:46 AM
greagin's Avatar
greagin
I replaced every pensioners and pulley on mine for 2 years before finding out it was the harmonic balancer. The rubber had hardened and worn on the damper ring causing it to hit the water pump pulley cockeyed thus causing a permanent squeal that took 2 years to find. Been quiet for almost a year now. Went thru countless belts tho, found the oreilly or napa hd belts to be the best, imo. Hope this helps
Old Jan 9, 2011 | 05:04 PM
nitro3421's Avatar
nitro3421
A little update: I took everyone's advice and looked into a bunch of things. It seemed the culprit was it being a new belt and the writing on the belt was squeaking on one pulley. I took some of the writing off and the problem seems to have gone away. Next step is a new tensioner and belt if it starts up again...
Old Jan 9, 2011 | 05:13 PM
maevans's Avatar
maevans
Good call nookie.
Old Jan 9, 2011 | 06:18 PM
big poppa's Avatar
big poppa
I agree with you and Mark, good observation..
makuloco2000
6.4L Power Stroke Diesel
Sep 22, 2013 09:40 PM
NVhunter
17
Feb 14, 2013 09:14 AM
themdgx
1983 - 2012 Ranger & B-Series
Sep 1, 2012 11:01 AM
aphotic26
Dec 3, 2008 05:18 PM
