Sponsored by: Real Truck
Transmission intermitting Problem HELP!
Old Dec 21, 2010 | 09:03 PM
DavidMcC's Avatar
DavidMcC
Post Transmission intermitting Problem HELP!
hey guys i have a 2004 F250 6.0L Turbo Diesel and Around 1500RPM i get a Shuttering like the Truck is Off Balance or something when i Step on the Gas or let off and it goes away the transmission guy said it feels like a Torque converter problem Any Help?
Old Dec 30, 2010 | 08:09 AM
DavidMcC's Avatar
DavidMcC
Still need help on This Problem,
thanks
Old Dec 31, 2010 | 03:00 PM
bill64's Avatar
bill64
its possably the torque converter is at fault, also other things that can cause that is drive shaft angles out of spec...lifted truck. a u-joint rusted or binding can cause that also
Old Jan 1, 2011 | 06:24 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Does it do it right off idle from a dead stop when you hammer the throttle? If it is most prevalent at off idle/from a dead stop situation, I would say you could very well have a spring wrap/driveshaft angle issue. Lifted Super Duties are terrible about this. Tire size, lift size, gear ratio, SB/LB, cab configuration, engine all affect it. Diesels are worse than Gassers. Shortbed 6.0's and 7.3's are the absolute worst. I have cured a bunch of them. Every truck is different, and some of them are not easy.
Old Feb 23, 2011 | 08:47 AM
DavidMcC's Avatar
DavidMcC
It only Does it at 60mph when its around 4th or 5th gear and at 1500Rpm and only will about 2000Rpm so its not from a Idle no.
