155: Wheelbase, 155"
X259: 8800 LB GVWR F250 extended cab 4x2
NDM: N(seat trim and style, my shop manuals are 84, don't have a N code) D: Medium red trim(dash etc) M: Supercab Styleside
K: C6 Automatic
C9: 6250 LB capacity Ford Limited slip axle with 3.55 gears(10.25 full floater)
3: White Tape Stripe, Explorer trim
gk: (spring codes, I can't decpher the listing in this book though)
1FT: Ford Truck H: Brake System: Hydraulic, GVWR: Class G, 8,501 - 9,000LBS
X25: F250 2wd Extended cab
L: 460 CI gasoline V8
X: Check digit
F: Model year, 1985
K: Assembly Plant, Kansas City
B07308: Production sequence #
