Sticky Key Cylinder
Old Dec 21, 2010 | 04:21 PM
fhafer's Avatar
fhafer
Sticky Key Cylinder
My ignition key is very sticky going from run to start. I have to turn it back to the run postion manually or the starter stays engaged. My truck is a 1990 F250 without tilt steering. I have the steering wheel off and I've sprated "PB Blaster" into the plunger assembly located inboard of the key/tumbler. It seems looser but can I disassemble this further to get inside this thing? I suspect old/hardened grease is fouling the spring mechanism.
I wish I could attach a photo.........
Old Dec 21, 2010 | 04:23 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Commom Ford problem, weak return springs.
Old Dec 21, 2010 | 04:32 PM
fhafer's Avatar
fhafer
Common Ford Problem
Will a Haynes manual tell me how to get to the spring to replace it? Can I replace an assembly to fix it? I have the 7.3 idi Haynes manual but not the one for the truck body.
Old Dec 21, 2010 | 04:33 PM
oreocreaming's Avatar
oreocreaming
its a total crap job. theres a gear selector that the key turns, that moves a pushrod down the center of the column and that activates the switch. if your not careful you will break the cast piece and you gotta strip it all apart. i had to do that when i got my truck. huge pita
Old Dec 21, 2010 | 04:42 PM
fhafer's Avatar
fhafer
Thanks
Thanks oreocreaming....that sounds like a resounding "White Lithium Grease" spray & pray. I'll lube it tomorrow morning and see how it goes.
Old Dec 21, 2010 | 05:12 PM
IDIDieselJohn
I never bothered with these things, I made it a habbit of pulling back the key. I only have to do it in the cold months anyways, never had a problem in the summer.
Old Dec 21, 2010 | 08:16 PM
Dave Sponaugle's Avatar
Dave Sponaugle
PB Blaster is a very good penetrating oil, but not very good as lubrication.
The PB Blaster will cut the crap loose, but then you need some type of lubricant to keep it loose.
White lithium, some spray oil like 3 in 1, Marvel Mystery or any of the many others out there.
Old Dec 21, 2010 | 08:21 PM
Scratcher's Avatar
Scratcher
I discovered that quirk this winter when my turn signals and heater fan stopped working. I'm on a manual return system now.
Old Dec 21, 2010 | 11:20 PM
idiguy's Avatar
idiguy
yeah i modified my ignition for "no key required option"
Old Dec 21, 2010 | 11:25 PM
oreocreaming
oh ya? did you alert your insurance to that little "mod"? lol
Old Dec 21, 2010 | 11:27 PM
IDIDieselJohn
It's like for a long time in my F250, I didn't even need a key to turn it on.
But after a year or 2, it started locking again, so was stuck using my key again. lol
Old Dec 21, 2010 | 11:34 PM
idiguy's Avatar
idiguy
of course oreo its my "advanced car alarm discount" on my bill lol
Old Dec 22, 2010 | 06:06 AM
powerstrokedieselfan's Avatar
Mine is really hard to turn foward to the start position when its cold outside, sometimes its almost a 2 handed ordeal. Is this a sypmtom of the same problem you all are having?
Old Dec 22, 2010 | 10:24 AM
fhafer's Avatar
fhafer
Working better....
I let the assembly soak overnight in "PB Blaster" then sprayed it down with white lithium grease this morning. I reassembled it and it works better......not as well as I'd like but it returns to the run position after the truck starts.
Sheesh......you'd think a twenty year old ignition would work flawlessly!?
Old Dec 22, 2010 | 12:47 PM
IDIDieselJohn
Yeah seriouslly eh?
After being used so much it should work with 1 finger! lol
Nope, gets harder with the years.....
ride_gnu
Jun 13, 2013 04:25 PM
88PONY
Apr 16, 2008 02:56 AM
scionti 94
1978 - 1996 Big Bronco
Sep 6, 2004 08:26 PM
