SCA test strips
Old Dec 21, 2010 | 04:37 PM
snaponprofile's Avatar
snaponprofile
Ok, so shouldn't I just forget the test strips and put the ford vc-8 SCA in since I haven't touched anything coolant related for 10K? Can putting in too much SCA hurt?
Old Dec 21, 2010 | 05:09 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Not really, but I heard it can cause little hot spots on the cylinder walls.
Old Dec 21, 2010 | 05:11 PM
snaponprofile
If its not treated with SCA's I would be able to put the recommended amount of SCA in, right?
Old Dec 21, 2010 | 05:15 PM
Scratcher's Avatar
Scratcher
Originally Posted by oreocreaming
why not just buy a good elc? then you dont have to worry about sca's at all? for anyone new reading this and wondering what sca's and elc is.... sca stands for supplemental coolant additive, and elc is extended life coolant.
Oreo, how long have you been running ELC in your IDI?
Old Dec 21, 2010 | 05:30 PM
ah1988's Avatar
ah1988
Dose any elc work or is there a certain brand that i would need to use in my truck ?
Old Dec 21, 2010 | 05:54 PM
powerstrokedieselfan's Avatar
I have just made the switch to CAT ELC coolant in my 7.3 Powerstroke and im planning on doing the same for my idi very soon. I bought a case of 6 gallons already pre mixed for like 80 bucks with tax I think it was. With the CAT ELC their is no need for adding SCAs and using test strips.
Old Dec 21, 2010 | 05:56 PM
ah1988's Avatar
ah1988
I dont have a cat dealer near me i just have autozone will any elc off the shelf work from there ?
Old Dec 21, 2010 | 06:41 PM
Any of the ELC coolants should work as they are precharged and are good for 3 to 400'000 miles of onroad use before they need an additive. Thats way longer than than I would let the coolant stay in my system and probably longer than our trucks will last on top of the miles they probably already have. You may see Final Charge Global on the shelf at autozone, its made by Peak and FWIW I run that in the DD15 in the semi I drive at work.
Old Dec 21, 2010 | 06:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
snapon you need to read this article in its entirety
Cavitation Article
if your interested in extended life coolant.see attached pdf.
File Type: pdf
Old Dec 21, 2010 | 06:57 PM
oreocreaming's Avatar
oreocreaming
i love CAT red, and ive got 4 dealerships within 45 minutes of me in every direction. a elc you get from the autoparts place will work.
Old Dec 21, 2010 | 07:00 PM
oreocreaming
personally 20k, p.o. said thats what he ran the last 60k.
Old Dec 21, 2010 | 07:58 PM
johnboggs21's Avatar
johnboggs21
I get my SCAs from John Deere
Old Dec 21, 2010 | 08:14 PM
  #28
Coalroller's Avatar
Coalroller
napa is a good place to get them from... i picked up a bottle with i believe 50 test stripes for around $18 and it has a color graph right on the bottle for your ph levels nitrate levels and i cant remember what the other one is sulfate maybe ill have to look. but anyway it will tell you if you need to add, how much to add or if it needs changed immediately
Old Dec 21, 2010 | 11:15 PM
  #29
snaponprofile
I should do a coolant flush in the spring then and put the right stuff in. I was hoping I could just put some SCA in but from reading that it looks like I would be doing a coolant flush anyways to get a 50/50 ratio of coolant to distilled water.
Old Dec 21, 2010 | 11:22 PM
  #30
Country_boy_2007's Avatar
Country_boy_2007
cat antifreeze kicks a$$. we overhauled a c-12 Cat with that coolent in it and there wasnt the least little bit of rust or scale in the cooling system that we could find. i however just use the standard green napa antifreeze and charge it with Napakool. its alot cheaper for me, and it dosent take much to check it with a strip.
