Ford and (Motorcraft) numbers:
Black hose, 1 required: F4TZ-9324-BA (KFL34)
Longer Blue hose, 1 required: F4TZ-9324-CA (KFL33)
Shorter Blue hoses, 2 required: F4TZ-9324-DA (KFL35)
Hose information for DIY:
Rated at 400 psi and ok for diesel fuel:
3/8" hoses: 2 required 2 " (fuel tank to pump &
low pressure feed from filter to pump)
1 required 2 7/8" (fuel pump outlet to filter)
5/16" hoses: 1 required 1 ¾" (FPR tubing)
1 required 5" (if replacing drain hose)
Thank a bunch, I work at a steel mill, and was talking to our hydraulic hose vendor. Could not remember the diameters so he could get me some "samples" free stuff. Thanks again.
