Need Help new Code and an old one 31CM & 34 KOER-updated need help again
You should be able to remove the screws that attach the EGR to the upper intake then pull on it a bit so you can slide some aluminum in there. Then button it back up for testing purposes.
As far as codes go it would not be a bad idea to check/clean the grounds on the fender, radiator support and block. Typically you would get a lot more issues, but it never hurts to check.
hmm theres more going on than EGR problems which is what I was afraid of,I tried the aluminum can between the EGR and intake and it made not appreciable difference in running condition I mean it ran a tiny bit better but not enough for that to have been the primary problem. now I'm thinking Fuel Pressure either the Regulator or the Fuel Pump it'self.
ke6jcf
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-30-2015 06:30 PM
Brandon Harrison
34
04-13-2014 12:17 AM
HateTank
07-27-2011 04:16 PM
