Hood scoop opinions
#32
There was a thread on here a year or so ago and there was a guy who did just what you are talking about. It was the BEST looking hood scoop I've ever seen! If he wouldnt have lived so far away from me, I would have paid him to make me one. And I also agree that those stick on ones look laughibly horrendous!
#33
Some of the scoops on these trucks look good if there done right an it is a working scoop not some cheap knock off you buy somewere. But I think the hood scoops look better on cars like Mustangs etc... then trucks anyway it looks more like it came from the factory an not just tossed on for looks like some people do with these cheap looking wings & exhaust setups they have.
#34
The one in the picture I would sell for 150.00, as the factory never painted the inside too well, there was some typical rust on the inside until I acid dipped it, you could powder coat it or POR15 the inside. The outside is pretty nice. The cast grille looks good too. Its about 2.5 inches tall, 18 inches wide.
I also may be able to get you an NOS unit without the grill.
Sam
#35
#36
#38
I've been searching for pictures of a guys shaker setup that shows this best, but no luck yet. You need to decide on the location of your shaker and then transfer this to the bottom of the hood. Next, transfer the carb throat location to the bottom of the hood. From here you can see what your offset will be.
Decide on the type of air filter housing you'll be using so you have a basic shape to work with. Using a dense foam you can carve it to transition from the air filter housing to the shaker. Foam can be carved easily, when you have your shape then spray it with sealer and then wax with mold release. Coat with epoxy and then layer fiberglass wetted with epoxy. Build up to the thickness you need. When dry apply fiberglass putty and smooth, allow to dry and sand smooth. Now your ready to pop the mold and primer and paint.
I'll keep looking for the pics.
#39
Get some sm foam like they use on concrete or walls (blue or pink) shape it to fit your breather up to your scoop, it's called a plenum. Once you have got the disired shape, glass it with matt and resin, once it's cured you can use thiners and melt the foam out.
Do some sanding prime and paint and vualla. Google it and you can get a visual so you can grasp the concept it's not the easist thing to do the first time but after one or two builds you will catch on quik and be making all sorts of things.
Please make sure you have adequate ventilation!! The vapors are not healthy...
#40
Here's the thread on the Maverick Grabber scoops:
https://www.ford-trucks.com/forums/9...ruck-hood.html
#43
#44
Pop's the short boss V scoop was used on the mach 1 mustangs. 69 and 70, they might have been on teh same year torino gt's also but I know it was the mustangs for sure.
got one sitting here I bought to put on the galaxie originally and then decided liked the boss 9 scoop on that big huge hood better.
#45
I kind of like the 429 scoop but was considering louvers on my hood like these
RunCool Real Heat-Escape Hood and Side Louvers
DustyRoadTruckinn
06-03-2015 12:43 AM
fordman75
58
12-18-2010 08:02 PM
cschannuth
05-03-2008 05:43 PM
