Intermittent speedo?
Old Dec 19, 2010 | 11:54 PM
SLUF681's Avatar
SLUF681
OK, so I'm driving down the road today and my speedo isn't working and my OD light is blinking. The speedo came back on after about 20 minutes of driving. Speed sensor crapping out? 2000 F350 CC DRW 4X4.
Old Dec 20, 2010 | 01:14 AM
SLUF681's Avatar
SLUF681
Also, my ABS light was NOT flashing.
Old Dec 20, 2010 | 01:38 AM
carltonwebb's Avatar
carltonwebb
More than likely VSS sensor in top of differential. Pretty inexpensive and really easy to change.
Old Dec 20, 2010 | 01:53 AM
SLUF681's Avatar
SLUF681
That's kinda what I was thinking. Just wanted a second opinion. I've seen other posts on here with this problem but it seems that the ABS light is usually flashing also. I haven't payed attention when starting the truck to see if the ABS light comes on when the key is on before starting. The bulb may be blown, hence the lack of flashing.
Old Dec 20, 2010 | 12:56 PM
Wayne64SS's Avatar
Wayne64SS
Mine did the exact same thing speedo dropping out / no abs light on though. Speed sensor fixed it.
Old Dec 20, 2010 | 02:15 PM
Kwikkordead's Avatar
Kwikkordead
Same here. One bolt and the sensor is out.
Old Dec 20, 2010 | 10:48 PM
SLUF681's Avatar
SLUF681
Thanks guys. I will be replacing the sensor this weekend hopefully if I'm not working. Hard to find a lot of time with a job and a business! That's a good thing though, right?
Old Dec 21, 2010 | 05:19 PM
lee231's Avatar
lee231
Same thing here, knock out the speedo, abs and cruise. VSS fixed it.
Old Dec 21, 2010 | 10:44 PM
SLUF681's Avatar
SLUF681
Is the VSS the one on the rear end or is it on the tranny somewhere?
Old Dec 21, 2010 | 11:13 PM
carltonwebb
It is the one on top of the rear differential.
Old Dec 21, 2010 | 11:14 PM
PaysonPSD's Avatar
PaysonPSD
The VSS (vehicle speed sensor) is on the rear pumpkin. The TSS (turbine shaft speed) and OSS (output shaft speed) are on the tranny.
Old Dec 21, 2010 | 11:25 PM
SLUF681's Avatar
SLUF681
OK. Thank you very much. I guess I'll go ahead and pick it up and slap it on Thursday when I do my GPR LED.
diesldoct
Apr 19, 2014 07:14 PM
armstrongz34
Aug 18, 2013 11:02 PM
Daltonsheets1995
Dec 4, 2012 07:19 PM
saltbranch
1978 - 1996 Big Bronco
May 24, 2012 09:20 PM
ken selvy
May 13, 2008 01:12 AM
