e350 payload question
Old Dec 19, 2010 | 11:42 PM
joelswork's Avatar
joelswork
Never thought I would be doing this but I have to pick up 2 tons of materials 300 miles out.....look at the pics, she's a beast....ok weight wise?
Old Dec 20, 2010 | 07:31 AM
johnboggs21's Avatar
johnboggs21
2 tons should be gravy. Ive had 2 tons in the back of my F250 like it was nothing.
Old Dec 20, 2010 | 07:37 AM
snaponprofile's Avatar
snaponprofile
Same here-I have 8 eight leafs in the back too. It could very well be different in a van though. How many leafs do you have??
Old Dec 20, 2010 | 04:58 PM
joelswork's Avatar
joelswork
5 leaves, 9400# gvwr but I took out 800 pounds of seats!
Old Dec 20, 2010 | 05:10 PM
snaponprofile
Just think-If its a 15 passenger van and made to take 15 people at the same time, if the average is 200lbs per person its made to take 3,000lbs. But part of those people are in the front and you will probably be putting the weight in the back so take into consideration that 5 of the 15 will most likely be towards the front so the suspension was in the back was probably engineered for about 1,000lbs. So minus the seats and you have the suspension rated for almost a ton. So if you plan on putting 2 tons in the back you might just sit it down close to the ground. I don't know if that makes any sense to you but thats the way I look at it
Old Dec 23, 2010 | 06:32 PM
joelswork's Avatar
joelswork
Got a ton and a half (fuel pellets) now for the 6 hour drive home...all interstate. E4OD, do I need it out of overdrive? I read it wasn't necessary but I just put 2k into rebuilding it......and don't want to do that again.
wpnaes
Jul 15, 2013 09:18 PM
Worktrucks
15
Feb 2, 2013 11:02 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
beartracks
Oct 18, 2002 02:20 PM
