Changed fuel filter today (trying to stop smoke at start up) and there's black stuff in my fuel any ideas on wut it could be would be great it was very small dots I could not fish any out
Does fuel from the fuel rails come back to the fuel bowl ?
And what does syn motor oil do in diesel will it bead up ? Reason I ask is I think I might have a bad injecter oring witch might let oil into my fuel is that possible ?
My fuel fitter was completely clogged up almost
My fuel filtter looks just like that and the next sad thing is I got fuel from shell for once usually kwik trip or BP never shell or mobil
Would algae grow in 5* weather though ? Its been super cold ?
This last week end I drove about 400 miles christmas shopping and noticed my 80eco setting wasn't throwing any black smoke at all usually its pretty black when I get on it on the on ramps so I just told my self to sea foam it and change fuel filter again just changed it about 8K miles ago not sure how often your suppose to I'd say once a year max or every 25K-30K miles
And I don't have a computer to upload photos witch really sucks but plan on getting one soon
You may have been getting enough fuel in 80e to perform well enough but not so much that it wouldn't all burn and cause rolling smoke.
Algae can form under the ice above the arctic circle, but if you got it from a storage tank it might be dead algae from the bottom of a very low on fuel storage tank.
Edit: Fuel filter should be changed at least every 15k.
Okay maybe it just needed to be changed then cause its been on for 6 months and. Almost 15K but I still don't like that there's black stuff floating around did you git the pics ?
I've also noticed since this smoke at start up started my mpg dropped about 8mpg I use to get 23 to 26 mpg hand calculated now I get 14 to 16 if I'm lucky this tank filled up yesterday have about 65 miles already went through a quarter tank usually I get about 115+ per quarter tank ?
Okay thanks clay ! First pic is new filter second is fuel bowl with a couple black dots (just drained fuel bowl and put new filter in so there's only a couple new pieces of what ever it is that in the fuel ) that are big anuff to see third pic is old filter with roughly 10-15K miles on it and was caked with that black stuff ill pull my fuel filter again and get some more pics to see if its gotten bad again it looked like floating dirt fine dirt but when I tried fishing some out with my finger it would disperse and I wouldn't have nothing except for a black smear mark on my finger ?
