E4OD is eating fluid! need help!
Old Mar 4, 2003 | 09:00 AM
ACRKENTUCKY's Avatar
ACRKENTUCKY
I have a 92 f150 with a 351 which is running to an E4Od. The transmission only has about 72,000 miles and is eating transmission fluid. I have put 4 quarts in the past month, and i have checked everywere and i have no leaks. i need help fast because im tired of buying transmission fluid all the time. I just changed the fluid in the summer too. Any bodys help would be appreciated.
Old Mar 4, 2003 | 09:31 AM
Racerguy's Avatar
Racerguy
If it's not leaking externally there are 2 places it can go.....into the transfer case through the input seal or into the rad through the cooler.
Old Mar 4, 2003 | 09:39 AM
ACRKENTUCKY
How would i go about fixing this, and diagnosing the problem?
Old Mar 4, 2003 | 11:51 AM
martyfowler's Avatar
martyfowler
check your transfer case fluid level. if it is way overfull it is probably leaking into the t'case. if so, there should be a seal between the trans and t'case, which would require removing the t'case to repair. if not that,look at your coolant to see if there is an oily film in it. if there is, you have found the problem. this would probably require radiator repair or replacement. hope this helps.
Old Mar 5, 2003 | 10:53 AM
bobbyredondo's Avatar
bobbyredondo
I dont know if this will help or not. I have an aerostar and it did the same thing. There were no leaks and it ate fluid. I ended up replacing my transmission on an all wheel drive and it was very expensive. According to the mechanic, it was some cheesy little 20-25.00 part called a modulator. Something caused it to end up being sucked into the exhaust. It was going right out the exhaust pipe. Hope this helps,bobby
Old Mar 5, 2003 | 02:26 PM
martyfowler
im not positive, but i dont think the e40d uses a modulator valve. it is electronically controlled. i have, however had that happen with a chevy transmission in the past. (th350). the modulator had an internal leak which let the engine vacuum suck the trans fluid right through it and directly into the intake manifold.
Old Mar 5, 2003 | 02:34 PM
AggiePSD's Avatar
AggiePSD
It doesnt use a vacuum modulator, so Racerguy is right with the only two places it could really go.
Old Jun 20, 2021 | 08:28 PM
Marshall Koch's Avatar
Marshall Koch
Just replaced my e40d and
Just replaced my e40d on my 95 f350 didny know I was killing my old one till it grenaded on me one day but install new one and smoking like crazy which thought was head gasket and had been fixed....still smoke but now clean fluid so I see that its red!! Where the halibut is the modulator which is 78 dollars at oreilly. Is it me or have they become Robery on their prices? But will let you know if that's what did it shortly with an up date thanks!
Old Jun 20, 2021 | 08:55 PM
rla2005's Avatar
rla2005
An ancient thread revived from the dead.
For the record an E4OD does not have a vacuum operated modulator. It is 100% electronic controlled.
More likely the front seal is leaking.
Byoung Oh
Mar 23, 2016 07:20 AM
scottyknows50
Apr 13, 2010 06:59 AM
Rockyray1
2004 - 2008 F150
Sep 3, 2009 06:10 AM
hunter_firefighter
Feb 13, 2004 05:18 AM
