i just changed my oil in my 94psd
after finished i found in the old oil filter what appers to be the spring,washer ,gate. of a checkvalve!!!no other parts like a snapring or anything else. seems to run fine but a little cooler. is this a pluged filter bypass? am i ok to go or ?????
i have another question if yaall can help..
whe i turn on my flashers or certain other accessories, plug into the camper power.
the ebgine stumbles n misses ,trys to stall
You need those pieces in the filter housing. IIRC your hpop resevoir will drain without it. There's pictures of it around here somewhere, hopefully someone will chime in and give it to you, I don't have it.
427 thanx
i take it "hpop" is high pressure oil pump ? iirc?
i will search around for pic,s
do i need to pull the houseing ? looks like it goes into a cooling tube ? and lines!
yep i could have very easly dumped them in the used oil drum !
it was chance that i didnt ! the weather was bad and i slowly poured it out into a bucket
i wonder how many trucks are out there without this check valve in them !!!??
i found a parts break down of the assembly it shows a snapring,, i cant see how the
parts could have made it into the filter this way ! it must have broken thru upwards.
this part list shows o-rings and ???? looks like if you dont repace everything, oil leak city.
thx
I take a WAG on this one, CPS (cam position sensor). I know not from experience but from reading on here plugging in a camper or trailer and if the engine trys to stall then replacing the CPS has resolved the issue. It's an electrical noise thing. Turn signals also generate electrical noise. Newer CPS's have better noise suppression filtering.
thanx all for the help, this is a great forum ! lots of knowlage out there!!
hussler: the wag sure fits and makes sense.
i have had this truck sinse it rolled off the rail car from the factory,been a
great work horse.
i was warned about the cps years ago, and bought one , thru it in the glovebox just in case! so i still have the factory senser in there.
cant find it anywhere now. i must have put it in my tool box at one time, but my tool box decided it didnt like me anymore and grew legs a few years back, that was a major p-off !!!!
