Pulled out fuse #41 on an '04 F-250 and the metal connectors in the slot broke somehow so when I went to put the fuse back in it wouldn't stay cause it wasn't making the connection. Can I fix it or do I need to buy a new central junction box?
You probably won't be able to fix the OEM box, and new ones are expensive.
If your not caring to much on looking factory, and have no warranty left, I would pull the wires out on the one that broke, buy a fuse and fuse holder from radio shack and wire that in to fix the problem. Just be sure to put the same size fuse in that you had before.
