Zf6 fluid change
Old Dec 21, 2010 | 01:15 PM
Wayne64SS's Avatar
Wayne64SS
Originally Posted by Visseroth
Use Syncro Mesh. You can get it from Napa. It's expensive but it's nice! It made my trannie much more quiet and smooth. I know because I need new sycros and they are noisy when they are worn.
It's about $15 a quart.
the pennzoil ****? i've have great success with the GM equivalent in all sorts of manual trannies (hondas, and my cobra).
Did you flush the cooler when you put this in or just drain and fill?
Old Dec 21, 2010 | 04:25 PM
Visseroth's Avatar
Visseroth
Nope. The trannie guy that I talked to said there shouldn't be any reason to flush the trannie with the syncro mesh.
Old Dec 23, 2010 | 11:09 AM
Fat Diesel's Avatar
Fat Diesel
Here's a pic of the oring on the plugs. It should be up near the lip and um... not pulverized. Does anyone carry these? Guzzle!!!
A 1/2" ratchet with a 3/8" reducer works well to drive them in or out.
Old Dec 23, 2010 | 08:18 PM
sticks25's Avatar
sticks25
My owners manual says that fluid capacity is 5.8qts for a zf6. is that including transfer case, cooler lines and stock radiator cooler? I drained from the bottom on both and was just wondering if I should fill to the top of the fill plugs. I just did a COMPLETE swap from a 97 e40d to a zf6 so everything got drained and flushed.
Old Dec 24, 2010 | 09:28 AM
Fat Diesel's Avatar
Fat Diesel
Transfer case is separate. It has its own fill and drain plugs.
I filled mine to the point of overflow yesterday. I'm going to run it a little to purge the air from my new lines then fill again to overflow. 5.8 might be the drain and fill, not purge capacity. Just have some extra ATF in case.
krustiy lusti
Dec 3, 2016 11:30 AM
chrison600
Nov 5, 2016 12:50 PM
johnno5
Alternative Fuels, Hybrids & Mileage
Oct 28, 2016 08:47 PM
n9zez
Apr 3, 2010 04:04 PM
