Vibration
Old Mar 4, 2003 | 01:48 AM
maury's Avatar
maury
Vibration
I recently bought a 95 Eddie Bauer F150 2wd and have been quite pleased with this fine machine except I'm getting a vibration in the seat of my pants when I reach 50 and up to about 65kph. Tires are new and balanced. u-joints 6 months old, etc. Heard rumors of two piece drive shaft not installed properly? Any info on this prob would sure be a great help. Vibin in Alberta!
Old Mar 4, 2003 | 02:30 PM
Cardinal's Avatar
Cardinal
Vibration
I've got a 94 XLT LWB and I have the exact same problem. The right rear tire (el cheapo Goodyear Wingfoots) was octagonal, so I had it trued, but very little improvement. It's hard to find a tire shop that'll shave tires anymore.
I'll keep an eye on this thread, maybe someone can shed a little light on the probable causes.
Greg
Old Mar 4, 2003 | 04:33 PM
groundrat's Avatar
groundrat
Vibration
I had a similar problem with my 94. I had Ford do a road force balance on my tires and they had to dismount two of the tires and rotate them 180 degrees then rebalance them. Worked like a champ. You may want to check the drive shaft and look for any clean spots where a weight may have been. However, if you can drive in to and out of the vibration, then I would suggest taking another look at the tires.
Bill
Old Mar 5, 2003 | 06:55 AM
Cardinal's Avatar
Cardinal
Vibration
I may just take it to Butler Tire here in Atlanta and have them check it out. They are renowned for fixing vibrations. I'm sure it'll cost me...
Greg
Old Mar 5, 2003 | 06:46 PM
groundrat's Avatar
groundrat
Vibration
Mine cost $80.00 at the Dealer and it was worth every penny. Best of luck to you.
Bill
Old Mar 9, 2003 | 03:00 AM
blue 79's Avatar
blue 79
Vibration
If you have a two piece driveshaft make sure it is in phase. Any good driveline shop should be able to help you out on this.
