Steering wheel
Old Dec 18, 2010 | 07:44 PM
doc11965's Avatar
doc11965
Steering wheel
On My 1995 f-150 i need to pull the steering wheel, so i can straighten it up
i have never done one, would somebody explain how to do so.....
Thanks Doc11965
Old Dec 18, 2010 | 09:19 PM
rikard's Avatar
rikard
Steve83 has a lot of info on the steering columns on his SuperMotor page. Remember to be careful when handling the SRS (airbag) and its related wiring.
regards
rikard
Old Dec 19, 2010 | 09:34 AM
rla2005's Avatar
rla2005
I would suspect it's not the steering wheel causing the problem. Unless a previous owner (PO) has jacked with it, my money is on the front end needing aligned. If there are no unusual tire wear or pulling to one side you could straighten out the wheel by adjusting the tire-rods.
On my F-350 4X4 there is a drag-link adjustment that is used for this purpose. Not sure if your F-150 has the same thing. If it does, there is no reason to adjust the tie-rods and/or steering wheel.
Old Dec 19, 2010 | 02:35 PM
doc11965's Avatar
doc11965
I had to replace the Stearing box, and pitman arm, so now i need
to straighten the steering wheel, i have never done one, and need
to have someone explain it to me if you will...
Thanks
Old Dec 19, 2010 | 03:46 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/2...ing-wheel.html Have a read here for steering wheel removal.
However it will not do what you want as the steering wheel has a master spline and so can only fit in one position. You will have to adjust it at the tie rods.
Old Dec 19, 2010 | 04:44 PM
Kapusta's Avatar
Kapusta
Could be easier to disconnect the coupler at the steering input shaft, center the steering box and steering wheel and then reconnect the coupler.
Ruffasacob
Oct 20, 2014 09:31 PM
EAK69
Nov 24, 2013 09:15 PM
tomrooster-1
Dec 14, 2012 08:22 PM
DR JOE
Aug 12, 2011 07:15 PM
NiNjA DoC
May 20, 2006 04:33 PM
