79/73 E-Brake question
Old Dec 18, 2010 | 04:49 PM
Mffix's Avatar
Mffix
So somewhere in the mix of things the 79 frame/e-brake and the 73 body comes up short. Anyone else have an answer to this? I would rather not go buy another brake cable or another truck for one part. I know I can make something, just need a push in the right direction!
So like a foot rod connecting the two with a brace/bracket? Anyone have a solution to this?
Old Dec 18, 2010 | 05:48 PM
Edgethis's Avatar
Edgethis
are you sure you got the right length cable from the cab?
Old Dec 18, 2010 | 06:22 PM
78 PEB's Avatar
78 PEB
Not sure its the "correct" way but I'd think you could make it work with a piece of all thread and a "coupling nut" from the Home Depot. If you dont know what a coupling nut is, it is a nut that is 1 1/2" to 2" long that you can "couple" two threaded rods of the same diameter and thread pitch together with. Think pipe coupling and youll get the picture. I know Home Depot has em............Ive used them on other projects.
Old Dec 19, 2010 | 09:11 AM
HIO Silver's Avatar
HIO Silver
If you do go the all-thread and coupling nut route, please use some red Loctite or, better yet, throw some tack welds on it.
Old Dec 19, 2010 | 09:16 AM
78 PEB's Avatar
78 PEB
Agreed............Should have probably mentioned it.
Old Jan 5, 2011 | 07:39 AM
dulockdrumheller's Avatar
dulockdrumheller
What you are describing is called a turnbuckle!
Old Jan 5, 2011 | 10:44 AM
AK FORD GUY's Avatar
AK FORD GUY
I think coupling nut is the correct term. A turnbuckle I believe has different thread directions on either end so that it either spreads or contracts when the turnbuckle is adjusted. A coupling nut is a long nut that is threaded completely through in the same thread direction.
Old Jan 5, 2011 | 11:01 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You are correct, the proper term is "coupling nut". The turnbuckle is used to adjust the length of a rod so one end is right hand thread and the opposite end is left hand thread. The coupling nut is right hand thread on both ends.
And yes, use Loctite on the treads. Personally I'd shy away from the welder. On a rod this small the weld might harden the metal and make it brittle, subject to cracking.
Old Jan 5, 2011 | 12:21 PM
seventysevenF150's Avatar
seventysevenF150
If your worried about it loosening even with Loctite, just grip the threads near the nut with vise-grips to slightly distort the threads, this should ensure that the nut wont pass that point (as close to the nut as possible) and won't be that hard to remove if needed.
Old Jan 5, 2011 | 12:30 PM
seventysevenF150
Sorry for the last post, for some reason I was picturing a turnbuckle in my head. You could use my idea in reverse to distort the threads slightly, add loctite and torque it together, if you can hang on to it..good luck.
Old Jan 6, 2011 | 05:25 AM
dulockdrumheller
I'm sorry I thought he wanted to add another rod then connect them together. A turnbuckle has two opposite ends with reversed threads so you can connect two separate threads of the same kind and pull up the difference, no left handed threaded rod needed
