oh yea, i have the e-cil with a green wire on one side and a blk wire with i think yellow or maybe it was white at one time that goes in theother side of the plug is gren hot?
My son took my 1980 F-150 to work. I noticed earlier when I drove it losing power. I thought it was not warmed up enough. When my son took it to work ran fine until the mourning. Turned over but would not start. His boss thought it was a coil. It turned out to be the carb was loose and when he continued pumping gas pedal he fouled the plugs. It has a 300cid Staight 6. He changed plugs , oil , and tightened carb and is running now.
thanks thats what i was thinking but it never hurts to check, everyone is at a loss around here. ok but would the sensor inside the disturbtor not let coil have spark on truck
Yep, the thing that goes round and round when the engine is cranking is what goes by the sensor, and the sensor tells the module you had checked at the store to fire the coil.
The sensor inside the dist tells the module to fire the coil. The module fires the coil by grounding and ungrounding the negative of the coil, while there is a constant + voltage on the positive of the coil.
You did the testlight test and the testlight did not blink on the negative wire of the coil with the engine turning. That means the module is not turning the coil on and off(grounding and ungrounding it). If the coil is not turned on and off constantly, then you will get no spark.
ok i think i got it now so i just ordered me a new distributor i'm to tired to fight with the gear, not only that i know its allnew mod. and pick up and gear thanks so much for your paitience with me i'll let you know after i get things put back together thanks again
