Bronco II Ford Bronco II
ignition coil testing
Old Dec 18, 2010 | 01:03 PM
Clint1973's Avatar
Clint1973
so my chiltons manual tells me that the primary resistance should be 0.3-1.0 ohms, (between +-terminals on coil) mine reads 0.6 good. secondary test is between - terminal and hi-voltage output should be 6,500-11,500 ohms, mine reads OL, bad right. Seemed simple enough till i bought a new coil from autozone and while building up my go outside in the cold nerves, I decided to check the new coil and got the same readings. So you figure I'm the lucky winner of autozones bad part inventory? Or do i need to check the secondary ohms on a 2k scale? that reads 8.06. I have a fluke 116 meter only bout a yr old.
Old Dec 20, 2010 | 08:50 AM
tommyleea's Avatar
tommyleea
Unless you have an auto ranging meter, you will need to set your meter to the correct limit. 2K won't read 6K. OK! Actually, you should be reading ohms to check the coil. Do you get the same reading from the tower to both terminals?
Old Dec 20, 2010 | 10:45 AM
Clint1973's Avatar
Clint1973
i put it on ohms, OL to either terminal, poked the range button and picked up 8.06 when i hit the 2k ohms
BigMightySam5600
37
Nov 28, 2016 06:46 PM
dnkensinger
20
May 29, 2016 06:22 PM
Cougar54
Sep 20, 2015 09:30 PM
acc7484
Electrical Systems/Wiring
Aug 11, 2005 10:22 AM
scharble
Sep 16, 2002 09:28 PM
