OBD II acting up
Old Dec 17, 2010 | 06:07 PM
Mr.ford's Avatar
Mr.ford
OBD II acting up
Hello all,
Now, I know this is a beating subject because I have search it and found lots of people having the problem but never get to the cause. I have a 1997 F-350 auto, 7.3 DI.
I can not get communication between scanner and truck, I have power at the fuses, the truck runs perfect. I have a DP tuner that I can not flash the PCM cause I can not get communication, I also have a Edge insight and that can not talk to the PCM.
Is it common for just a plain bad connector? I just cant see it ....
any ideas ?? (spent a lot of money on tuners and monitors to not work!)
Old Dec 17, 2010 | 06:19 PM
RRranch's Avatar
RRranch
How long have you had it? Someone may have put a junkyard 94 computer in it. I'd pull it and check the code just to be sure. 94's will run fine on your truck but the obd2 DLC will not work.
Old Dec 17, 2010 | 06:27 PM
superduty4x4's Avatar
superduty4x4
There is also the possibility of some hacked wiring somewhere.
Old Dec 17, 2010 | 06:41 PM
Mr.ford's Avatar
Mr.ford
If it was a 94 computer what will tell me that. I've had the truck now for 2 years. All I know it was a company and plow truck before I got it
Old Dec 17, 2010 | 06:45 PM
superduty4x4
You'll have to pull the PCM to see what the program code on it is.
Old Dec 17, 2010 | 06:56 PM
Hussler's Avatar
Hussler
I have to ask, does the cigarette lighter work?
It powers the OBDII port.
Old Dec 17, 2010 | 07:03 PM
bad12jr's Avatar
bad12jr
The edge evolution cts I won wouldn't communicate with my pcm until I removed the chip.
Old Dec 17, 2010 | 07:12 PM
Mr.ford's Avatar
Mr.ford
lol, of course, yes both of my cigarette lighters work(power point)
and what chip are you referring too?
Old Dec 17, 2010 | 07:28 PM
bad12jr's Avatar
bad12jr
My PHP tuning chip in the pcm. U may have to remove the dp tuner.
Old Dec 19, 2010 | 12:58 PM
Mr.ford's Avatar
Mr.ford
well, I pulled the pcm today, code on it is TDE1 so were good there OBD II,
still no comm between pcm, and DP tuner.
Old Dec 19, 2010 | 02:25 PM
bad12jr's Avatar
bad12jr
Did you clean the contacts on the PCM before you installed the dp chip. I thought the problem was the Scanner and the Edge Insight?
Old Dec 19, 2010 | 03:34 PM
Mr.ford's Avatar
Mr.ford
no chip i have a x3 power flash
Old Dec 19, 2010 | 05:32 PM
bad12jr's Avatar
bad12jr
Ok makes more sense. Dp tuner is normally a chip that's where I got that. Honestly check to make sure no one installed a chip in the back of the pcm. I know you took it out but did you check.
Old Dec 19, 2010 | 06:24 PM
Mr.ford's Avatar
Mr.ford
well, i never opened it up , but it looked like a normal pcm, little corrosion on the outside nothing out of the norm ..
Old Dec 19, 2010 | 07:56 PM
bad12jr's Avatar
bad12jr
It would plug in from the back of the pcm. There is a plastic cover from the factory over the hole. You can take the park brake bracket off and look and see. It's very easy to see. Most people will put duct tape across a chip to hold it in place.
