Backfire
Old Dec 17, 2010 | 04:40 PM
lucysw's Avatar
lucysw
Backfire
My 1995 F150 backfired I think due to bad gas. The engine runs but now there is a load tap from what appears lifter galley. Any suggestions?
Old Dec 20, 2010 | 06:51 PM
taisa899's Avatar
taisa899
did it backfire out the tailpipe or through the throttlebody?
Old Dec 20, 2010 | 07:35 PM
lucysw's Avatar
lucysw
Through the throttle body.
Old Dec 20, 2010 | 08:38 PM
f-150_1993's Avatar
f-150_1993
You might want to check your timing. Lets see... Might want to change plugs, rotor, and cap see if it makes a difference.
Old Dec 20, 2010 | 09:17 PM
lucysw's Avatar
lucysw
The timing is fine and all the plugs and rotor and cap has been changed. The backfire I think was caused by either bad gas or something going on with the TPS. After I finally got it started now it has a loud tap on top of the motor.
Old Dec 20, 2010 | 09:48 PM
f-150_1993's Avatar
f-150_1993
Definitely forgot to mention the TPS. Yes could be the problem. How much of that bad gas you got left in the tank?
Old Dec 21, 2010 | 08:27 AM
lucysw's Avatar
lucysw
I think I got all the old gas out. Truck runs good but now i am worried about the loud tap. i am going to have to pull the valve covers off to see if something is bent.
Old Dec 22, 2010 | 03:24 PM
f-150_1993's Avatar
f-150_1993
That sucks. Umm... yo do that and report back here. My engine has a slight knock due to loss of oil psi. Gotta get that worked out soon.
But why would something bend? Was the tap there before? Maybe the engine never backfired lol maybe if was something else.
Old Dec 22, 2010 | 04:17 PM
lew52's Avatar
lew52
Yeah pull the valve covers & have a look , if its poping though the intake thats a good sign you have a problem with an intake valve , the noise and back fireing are probably the same problem...Lew
Old Dec 22, 2010 | 04:29 PM
lucysw's Avatar
lucysw
Pulled the intake and I have two bent pushrods. They are intake push rods on different cylinders. What would cause this?
Old Dec 22, 2010 | 04:37 PM
lew52's Avatar
lew52
Did the truck sit for a long time ? you could of had a lifter or vavle stick , have a good look at the rockers to...
Old Dec 22, 2010 | 04:42 PM
lucysw's Avatar
lucysw
Got the motor from a junk yard but have been driving it before this happened. Motor sounded and ran great. It is suppose to have on 35000 mile on it total.
Old Dec 22, 2010 | 04:56 PM
lew52's Avatar
lew52
After you replace the push rods spin it over a few times before you put the covers back on , and see if they look ok , all the valves should be the same height when the valves are closed...
Old Dec 22, 2010 | 07:02 PM
f-150_1993's Avatar
f-150_1993
I suppose you don't run it hard. You never mentioned if it's a 302 (5.0)or a 351 (5.8). Wait so if you were running it then how did you get bad gas in your tank? The most reasonable way as lew52 said is that it was sitting for quite some time.
Old Dec 22, 2010 | 07:07 PM
f-150_1993's Avatar
f-150_1993
hey lew52 have you ever removed the oil pan to change out the oil intake screen and oil pump on these 92-96 f150's? It's time for me to make a move soon cause my engine is starting to develop a slight knock. I have inspected valves, pushrods, and rockers. They all seem fine. See it stops knocking over 1,000RPM when it gets pressure back up but idling is where it already got annoying. *tap tap tap
