2003 f250 super duty 6.0l diesel glow light turns on while driving down road
Old 12-18-2010, 06:48 PM
reed19889's Avatar
reed19889
reed19889 is offline
its weird it doesnt do it all the time i put heat shrink and tape on it so hopefully that was it
Old 12-27-2010, 08:40 PM
reed19889's Avatar
reed19889
taped up wire thought it fixed the issue then while driving today it happened like 6 times its getting worse
Old 12-27-2010, 08:53 PM
cheezit's Avatar
cheezit
cheezit is offline
the wire damage you are looking for should be on the main engine sensor harness. suspect spots are near the gpcm, near the ficm and near the crank case breather.
Old 12-28-2010, 01:33 AM
IHbase's Avatar
IHbase
IHbase is offline
Follow Cheezit's advice- and if you do a search, you'll find photos of Ford's many wiring issues. The photos will be a big help in finding the locations cheezit mentions because they wear locations are not obvious unless you know what you are looking for.
-mike
Old 12-28-2010, 07:03 PM
reed19889's Avatar
reed19889
the whole engine wiring harmess is so cramed i there in so many locations its kinda nuts where are all those items located at i now where the main harness is thas it it lookes like the only way to see if the haress is chaffed in several locations is to remove it since its so tight is it ok to disconect the harness es to flip wire up and check it
rmurray
04-11-2021 06:59 PM
1986f350diesel
11-15-2016 09:43 AM
bpete
01-16-2016 01:24 PM
neilwpitts
1999 to 2016 Super Duty
12-30-2015 05:35 PM
F 250 6 liter
01-18-2011 01:06 AM
Quick Reply: 2003 f250 super duty 6.0l diesel glow light turns on while driving down road
