key switch
Old Dec 17, 2010 | 04:25 AM
richdavis69's Avatar
richdavis69
key switch
I need to change the key switch out on my 95 f-250 and on my 96 f-150 some people say its an easy job. just trying to get some insight from others who have done this on a ford of that model
Old Dec 17, 2010 | 04:37 AM
jplinville's Avatar
jplinville
If you have tilt steering, it's VERY easy. Under the key socket is a hole. You'll need to turn the key to the on position and press a small diameter drill bit in the hole, depressing the lock, then pull the assembly out. It goes in the same way.
Old Dec 17, 2010 | 07:29 AM
richdavis69
ok, that takes care of the 96 f-150 the 95 f-250 does not have tilt wheel. Is this where things start to get ugly
Old Dec 17, 2010 | 12:11 PM
richdavis69
actually if there is a shroud over the steering column you can replace the key without removing the steering wheel. THe inside of the gear on the column (farthest inside) was packed full of metal from previous key cylinder(s)wearing out. Took a dremel and began grinding the inside of the gear so the the end of cylinder key would fit, when a molded peice of thrash metal popped out, it was perfectly formed to the inside of the gear leaving the slot unaccessible . After that the key was easy. Also the bracket before the gear goes tooth in and is a pain in the ****. Hope this helps anyone in the future. Will post when I do 96 f-150 tilt wheel
