my wipers r dying... only the low n high r working. my squirts dont work.. have winter fluid in tank but they dont even make noise when prompted to. wipers also make grinding noise like teeth on motor aint catching. how hard is it to replace wiper motor n squirter thing? where r they located? how much do they run? need this done asap lol
First off, I have to say, I LOVE your title. It made me chuckle.
Anyways, try pulling the end off of the lever on the left side. The end of it is just a cap that pries off. Then remove the phillips screw in the middle of it. Carefully, making sure to catch the pin and spring that may fall out, remove it. Clean up the insides of it with rubbing alcohol and q-tips. Then, using dielectric grease, lube it all back up and put it back together. Give us an update after you're completed this.
