Manual hub question?
Old Dec 17, 2010 | 07:32 PM
JonathanN's Avatar
JonathanN
Actually, you can loosen up those hubs quite a bit... I took mine completely apart and then dumped transmission oil into them and let it sit. After it set awhile, I worked the **** back and forth and it loosened up really good once the oil worked itself down into the O-ring the seals the **** off. Give that a shot before you drop a bunch on a new set of hubs. I had about 298K on the truck when I did this, BTW...
Old Dec 19, 2010 | 06:59 PM
lhud's Avatar
lhud
Jeremy,
I do like the MBRP. In my opinion, it is just a little louder than the OEM system, but for me not annoying. I do not have any gauges, so I can't help with the temps, etc.
