heater issues 2000 expedition
Old Jan 12, 2015 | 09:48 AM
alloro's Avatar
alloro
Originally Posted by BSarkFord
got 2 plastic Ts from the Boys of Pep.
I was going to suggest plastic over metal because of oxidation factors, but the flipside was that plastic, if not the right kind, might crack or not withstand the heat.
Old Jan 12, 2015 | 11:52 AM
BSarkFord's Avatar
BSarkFord
They are heater hose fittings, so should be designed for the heat, chemicals...we hope!
Old Jan 12, 2015 | 12:26 PM
alloro's Avatar
alloro
Well thankfully you had the good sense to use the correct type of plastic fittings. Many would've gone to a hardware store or Home Depot and got those plastic underground sprinkler fitting.
Old Feb 9, 2015 | 11:25 PM
BSarkFord's Avatar
BSarkFord
That's probably what I would do too.
I replaced the front heater core, have TONS of heat now, but no cold. Here in L.A. that is a must, even in "winter."...what do you think, blender door motor? Take it all apart again? How can I check it's working before reassembling it all again? I noticed when I reassembled it, the door would only go back in in the all the way open position. Don't think that matters, it's just where the motor or relay stopped.
Thanks for any help.
steuspeed
Apr 24, 2026 06:45 AM
Fixnstuff
Nov 12, 2018 11:23 AM
ExBeast
Jul 13, 2016 04:24 PM
D & D
Sep 28, 2014 05:24 PM
MUDBUCKET
1978 - 1996 Big Bronco
Apr 27, 2014 08:42 PM
