4" Lift maybe
Old Dec 15, 2010 | 06:04 PM
mhancock2's Avatar
mhancock2
4" Lift maybe
I have a 2wd Ford F-350 diesel. There isn't a lift available for this truck, or one that I can find. Looking at it all I would need is longer coil springs, longer shocks, then blocks in the rear? Anything else?
Old Dec 15, 2010 | 06:09 PM
zxwut?'s Avatar
zxwut?
yes, a lot else
Old Dec 15, 2010 | 06:30 PM
L. Ward's Avatar
L. Ward
Skyjacker Suspensions 186F2K - Skyjacker 2WD Suspension Lift Kits - Overview - SummitRacing.com
Old Dec 15, 2010 | 08:32 PM
mhancock2's Avatar
mhancock2
That won't work with my diesel engine.
Old Dec 15, 2010 | 08:33 PM
mhancock2's Avatar
mhancock2
IF that would work I would be all about that.
Old Dec 16, 2010 | 09:20 PM
mhancock2's Avatar
mhancock2
Fabtech has a couple of kits for my truck all the kit includes is 2 coil springs and block spacers for the rear. The kit number is FTS129, FTS129BK, FTS127
Old Dec 16, 2010 | 09:58 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
Won't the BDS kit work?
Old Dec 16, 2010 | 11:16 PM
92-150man's Avatar
92-150man
if you lift it high enough (4 inches like youre saying) youll need to get extended brake lines, probably sway bar extensions, probably end up needing camber bushings for the front end, ect
Old Dec 17, 2010 | 06:27 AM
L. Ward's Avatar
L. Ward
My guess is the reason it doesn't cover the diesel is the springs don't have the weight rating for the added weight of the diesel. One option might be to add these to the kit for the added weight of the diesel
Ford Air Spring Kits - 1980-2004 Ford F250 / F350 2wd - "Air Lift 1000" Air Helper Spring Kit (FRONT)
Old Dec 18, 2010 | 04:32 PM
mhancock2's Avatar
mhancock2
Ok one of the kits from Fabtech does say you need the camber kit. The other one does not. I would call Fabtech before I bought anything.
Old Dec 18, 2010 | 04:41 PM
47ltb's Avatar
47ltb
Originally Posted by zxwut?
yes, a lot else
Like maybe a "Body Lift"?
Old Dec 18, 2010 | 04:45 PM
zxwut?'s Avatar
zxwut?
sure
Old Dec 18, 2010 | 04:49 PM
White 97 xlt's Avatar
White 97 xlt
He said he wanted top LIFT the truck, not RUIN it!!!!!!!!!
Old Dec 19, 2010 | 11:32 PM
mhancock2's Avatar
mhancock2
Also there again body lifts aren't offered for the diesel. I would rather have a suspension lift. How much of a weight difference can there be between the 7.3 and a big V8 gas engine? Or is it more of the presumed hauling weight of the diesel vs the gas motor that makes the difference?
Old Dec 20, 2010 | 08:46 AM
47ltb's Avatar
47ltb
Sure they make body lifts for a diesel, I have one on my diesel.
