Speedo bouncing all over 96 350 5.8L
My Speedo seems to bounce all over hell, accompanied by a small ticking sound. it does it at odd times, not everytime i drive it. it will just do it for a second, then go back to normal. This is a 96 F350, 5.8L auto 4wd. Truck has 63k orig miles, but plenty of western ny rust underneath. Any info is appreciated fellas!
Your '96 does not use a speedometer cable. The speedometer is electronic. The VSS sensor on top of the rear end housing generates the signal for the speedometer as well as the RABS module.
There is a box under the dash that converts the VSS signal to something usable for the speedometer to measure called a PSOM. I would start by removing the VSS then inspect/clean it. This is the most common cause of your issue.
My RABS module causes mine to have a slight bobble all the time and to fluctuate a little which is about 5 mph randomly at highway speed. I leave it unplugged, since I can't figure out whats wrong. I have tried 2 new/reman ones and 3 used ones. Some work better than others.
Try unplugging it and see if your problem goes away. I would do this test first since its free and the easiest. Its the black box in front behind the glovebox.
I agree that the VSS is generally the issue.
If you swap the sensor and find it isn't the cause you'll have to open the differential to check the exitor ring. The teeth on that ring causes the signal on the sensor, so if it's broken the signal will make the speedo jump, if that is the case you should look at other damage or wear on the diff.
Dean06919
05-19-2017 04:50 AM
96inline
11-08-2015 08:59 PM
BC_Caprice
02-18-2013 09:43 AM
