Hdro booster
Old Dec 15, 2010 | 09:27 AM
mmenzies's Avatar
mmenzies
Hdro booster
How big of a job is it to change out the hydrobooster unit. IS this a job for the dealer or can any mechanic pro or amateur do this.
IS there any gasket that goes between the hydrobooster unit and the brake master cylinder.
Thanks in advance for advice.
Mark
Old Dec 15, 2010 | 11:59 AM
mmenzies's Avatar
mmenzies
Any help appreciated
Looked in the tech folder and couldnt find anything there
Mark
Old Dec 15, 2010 | 08:56 PM
cheezit's Avatar
cheezit
farily stright foward job. 4 bolts inside and 2 outside. just unblot the master and lay it to the side. also improtant do not cross the hydrolic lines. mark them to make sure this doesnt happen.
Old Dec 16, 2010 | 11:05 AM
mmenzies's Avatar
mmenzies
Thanks cheezit for the input.
Any idea on if there is a gasket required between the Master and the hydo. Want to be sure I have all the required parts befpre starting.
When you say 4 bolts inside and 2 outside you mean 2 bolts on the master and 4 on the hydro. By inside do you mean there are nuts on the inside of the cab where the booster attaches to the wall. (looks from a cursory glance as if the bolts go into a pre threaded receiver.)
Mark
Old Dec 16, 2010 | 06:13 PM
cheezit's Avatar
cheezit
look up under the dash. its been a long time sence I have done one.... should be 4 nuts under there
there is no gaskest the hydor boost unit is sealed
okie72
Feb 15, 2014 09:35 PM
F250racer
Feb 17, 2011 03:58 PM
78_f800crewcab4x4
Feb 21, 2008 05:00 PM
