1978 - 1996 Big Bronco
engine will not crank, intermitting
Old Mar 3, 2003 | 04:49 PM
cbota's Avatar
cbota
Hi everyone,
I have a 96 ford Bronco and twice in the past week it would not turn over. Both times it has been after the engine was turned off and tried to be started again in about 15 minutes. I hear the fuel pump pressurize but then nothing else. The 1st time I tried to jump start it but it did not work. The battery had corrosion on it so I cleaned up the connections and the engine started. So I figured the problem was solved, but then today the vehicle was parked for 10 minutes and then would not turn over again. The Bronco then sat for 2 hours and when I tried to start it again it started right up. I did nothing to the vehicle, it just sat for 2 hours in 10 degree temperatures. So any advice would be greatly appreciated, Thanks, Chris
Old Mar 3, 2003 | 04:54 PM
Kemicalburns's Avatar
Kemicalburns
Take the battery down to a parts house and get it tested along with your starter. its free
Old Mar 3, 2003 | 05:00 PM
alanscott's Avatar
alanscott
Make sure all of your connections are clean and in good shape, both sides of the starter relay and at the starter itself.
If all of this fails, I would say the starter itself is on it's way out.
Welcome to the Site!
Old Mar 3, 2003 | 05:04 PM
bigk300's Avatar
bigk300
if the starter tests good look for a fuseable link between the starter and battery also check starter relay
Old Mar 3, 2003 | 05:52 PM
Kemicalburns
also the cold could be affecting the silanoid that is mounted on the fender wall. those are cheap and cause similar problems
late
Old Mar 3, 2003 | 07:30 PM
marshall0351's Avatar
marshall0351
check the connection at the starter selenoid trigger wire,(flat blade terminal, small wire) ford has a revised terminal repair kit for just such conncern.
Old Mar 4, 2003 | 11:39 AM
Hawkk33's Avatar
Hawkk33
Post engine will not crank, intermitting
Had the same problem about a week or so ago (87 Bronco).,.. i replaced the solenoid and it kicked over once but died again so I moved onto replacing the battery cables, and the starter and threw in some new plugs for good measure. starts good now. Thinking of going one step further and replacing cap and rotor as well.
rowley
Feb 28, 2013 07:20 PM
msfprobass
Jun 1, 2012 05:57 PM
63' f100
Nov 4, 2010 01:09 PM
farmboy1432
Oct 21, 2010 06:02 AM
Chris89lx
Bronco II
13
Apr 18, 2004 10:00 PM
