Offroad & 4x4
Help with 4X4
Old Dec 13, 2010 | 09:46 PM
TruckinAL's Avatar
TruckinAL
Help with 4X4
I not long ago got my first FWD truck 97 XLT 4.2 . And for the life of me I can't figure out how to get it out 2 HI in to any other range. When I pull on the shifter it won't move like it is locked or something. Oh by the way it is a manual 5 speed .
I tried putting the gear shifter in neutral and pulling on the FWD shifter and nothing . Could there be an electrical something going on ? Is there a switch connected to the clutch pedal that could have gone bad.
It is not a piority at this time because I have it torn down for head gaskets , but I just like to know . Thanks in advance
Old Dec 13, 2010 | 11:21 PM
fatdan460's Avatar
fatdan460
pretty sure all you have to do is put it in neutral and push down on the t-case lever and then pull back. you might have an issue with froze up linkage, or tweeked linkage that is binding. easiest way to figure it out is crawl under there and take a look. never hurts to spray it all up with some kind of lubricating oil.
Old Dec 13, 2010 | 11:26 PM
TruckinAL's Avatar
TruckinAL
Thanks I never thought to push down . I pulled up on it tried to push it to the side. Hummmmmm I'll try to push down Thanks again and if that don't do it I'll crawl under it like ya said . The PO said it worked i'll see though
Old Dec 14, 2010 | 05:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
typical problem with those 4X4 shifters.
the shifter brackets are made out of aluminum, and get all cheesy from lack of use. worst case scenario is you are gonna have to take it off and apart to clean it up and lube it all up before reassembling it.
Old Dec 14, 2010 | 11:06 AM
l67cooled's Avatar
l67cooled
I have to lube mine up now and then or I'll have the same problem. It tends to get muddy or froze up with snow in my case.
Old Dec 14, 2010 | 11:58 AM
captain p4's Avatar
captain p4
sounds like a personal problem
Old Dec 14, 2010 | 01:09 PM
77mud's Avatar
77mud
That it does!! LOL
Old Dec 15, 2010 | 09:26 AM
alpha/omega's Avatar
alpha/omega
bwahahahahaha!
Unklebob
Apr 2, 2015 11:49 AM
msalyer
Crossovers
Feb 27, 2013 06:54 PM
Daewoo
Feb 1, 2012 01:00 PM
rlbrons
18
Jan 22, 2012 05:56 PM
mike_rockwell
Jan 15, 2010 05:52 PM
