Bronco II Ford Bronco II
1986 broncoII brake pedal sticks.any ideas?
Old Dec 13, 2010 | 03:56 PM
jaceqq's Avatar
jaceqq
Just picked up 1986 II ... brakes seem to work fine except the pedal wants to stick in the down position, can but foot under pedal and pull right back up and brake will release... any ideas where to start looking? thanks Jace
Old Dec 14, 2010 | 05:04 PM
mdr617's Avatar
mdr617
Ithought that the hydrolic pressure was what pushed the pedal up. I guess i would sart by bleeding the brakes really good all the way around. Maybe check to make sure the calipers and rear wheel cylinders are working right. If it still does it, maybe look into replacing the master cylinder
Old Dec 15, 2010 | 09:22 PM
jaceqq's Avatar
jaceqq
thank you. i will try that first.i"ve never had or heard of a brake pedal not comming back up unless a line blew.
Old Feb 6, 2026 | 01:53 PM
Nitro206's Avatar
Nitro206
5th Gear
Did you find a solution for this
it’s happening to my 1976 Ranger I have breaks but when I fire up the truck the pedal doesn’t returned all the way causing undesirable breaking
Hyakkimaru
33
Apr 3, 2023 07:00 PM
eriksf250
23
Jun 18, 2022 12:03 PM
Jspafford
Bronco II
Dec 7, 2007 05:52 PM
Dads79
Apr 22, 2007 10:19 PM
Sycostang67
Feb 16, 2005 01:11 PM
