Dead brake pedal
Old Apr 22, 2007 | 04:53 PM
Dads79's Avatar
Dads79
Dead brake pedal
I'm working on a 78 F-150 that hasn't been on the road in two years. The brake pedal was very stiff. So today I changed the Master cylinder and bled the system. The pedal freed up a little and the brakes worked barely. The pedal is still soft and does not return to the up postion. When I bled the brakes very little fluid would come out with each cycle of the brake pedal on the down stroke. Whats next new brake booster ????? Thanks for your help.
Old Apr 22, 2007 | 05:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
It sounds like the MC was not bled properly. Also lubricate the brake pedal pivots.
Old Apr 22, 2007 | 06:03 PM
Mil1ion's Avatar
Mil1ion
I think you have seized calipers or wheel cylinders.
If these braking systems aren't used they seize up from lack of use.
Old Apr 22, 2007 | 10:17 PM
rusty7983's Avatar
rusty7983
hi, i had a ranger that the master cylinder leaked into the booster. the pedal would stay down. i eventually repaired it. there was a cup of brake fluid in the booster.
Old Apr 22, 2007 | 10:19 PM
rusty7983's Avatar
rusty7983
unless you spilled some check at the rear of the master where it meets the booster, is it wet and rusty? thats a sure sign of a leaky master.
