428 TROUBLES
I have a 428 in my truck. Most likely a Q series. I bought the truck back in June. The engine has a Carter AFB carb on it, not sure of the CFM. When I got it it seemed to idle high. I played a little with the carb adjustments without much change in the idle resulting. When I had her on the highway above 40 mph and then got into it, it would "ping" like crazy ( just a note: the ping existed before I played with the carb ). So I played around with the timing and retarded it by ear. This brought the idle down somewhat and the pinging went away on acceleration. I have also noticed that it tends to be a little more sluggish as a result. It seemed to be a bit more spunky with the timing advanced. Also, when it has been running for more than twenty minutes (est. ), when I turn off the ignition she sometimes diesels and sputters ( no back fires ) kind of like: chugga-chugga brt-brta-brta hissssssss ( best I can do in replicating the sound
).One thing I couldn't see when I went looking is any timing marks?
In the spring I plan on putting a new Holley 650 - 700 CFM on her and getting a tachometer. I had a compression test done back in August and the compression is solid across all eight ( 155-165 ).
Aside from what I have stated she runs fine and she definitely has a drinking problem!
If anyone knows anything about this AFB carb (4V ) I'd appreciate any input. It only has two adjustment screws that I could find and no other points ( obvious ) for adjustment.
So, do you guys think I need to advance the timing somewhat or just run her like she is? I know one thing for certain, she is definetly running rich. My dual exhaust is black as coal at the tail pipes.
Did you clean the balancer real good and not see any marks? If so, you can get it to number one and put some timing tape on it.
Either that, or the vacuum advance isn't adjusted right, or just plain not even working anymore, and someone played with the initial timing to get it "peppy" again and caused the pinging.
Time it at like 6 degrees BTDC at idle, and while watching the timing, bring the RPMs up to 3000 and see what it does. Try to write down what the advance is every 500RPMs or so, and report back with the numbers and the guys will definitely have more to go on.
Go over the damper, find the "0", and every 10 degrees BTDC another line, and use white paint with a thin brush to mark each line and maybe a number if you can get it on there. It should be very easy to see with the timing light after that
Not sure what equipment I need to do what you said in the third paragraph above. I only have a timing light. What do I need to read the advance? Is there a portable ( cheap ) tach I can get to hook up under the hood to get RPM readings as well?
Being a shade tree mech. I am used to basic stuff. I love to learn though. And I can say with all honesty that I do love working on my old girl. Can't say that about the new stuff!
Ooops! I think I know what you mean now. Check the reading on the damper @ 500 rpm intervals and document? Still need advice on gauge for tach under hood. Thank you, Todd.
Thank you sir! Still a little rusty doing stuff since I had my 65 F100. Perishable skills as they say.
I'll check out NAPA for the tach/dwell meter. Curious? Does a dwell meter work with electronic ignitions? No points = no dwell?
The "dwell" is the amount of time that the points are closed, energizing the coil.
The reason I said a tach/dwell meter is that you are probably going to be stuck buying something that does dwell as well (pun intended). Still shouldn't be a big-buck item though.
I have an idea, from Napa, you're going to get this:
Store Locator | NAPA Online
