Upfitter install help?
Old Dec 13, 2010 | 10:49 AM
RBolton6's Avatar
RBolton6
OK, I screwed up and didn't get it from the factory but I did end up buying the add-on. I've read all? of the previous threads about it taking only a hor in to install and I must commend you all! I've hit a dead end. I've removed the left side end cover and the lower panel from the steerrng wheel easy enough but I can't see any way to mount the relay box to OEM holes. From the left side there is a small 2"x2" box directly in the way. It seems like the best way would be to remove the trim holding the dimmer switch but don't want to snap a high priced piece of plastic. Any ideas? I have the Lariat Ult pkg so maybe that's why it's so crowded. Haven't even looked at the switch mount yet....
Thanx
Last edited by RBolton6; Dec 13, 2010 at 11:28 AM. Reason: figured it out...don't ask...
Old Dec 13, 2010 | 01:35 PM
kper05's Avatar
kper05
If you say don't ask after figuring it out, you know we're going to ask! Haha.
Old Dec 13, 2010 | 01:41 PM
Adobe 11SD's Avatar
Adobe 11SD
Yep --- what was the solution??
Old Dec 13, 2010 | 01:52 PM
RBolton6's Avatar
RBolton6
OK, I guess I deserve it... unclipped the small box in the way, unclipped the relay box from the frame and mount the frame first, then the relay box and finally the small box again. Funny how a little break will let you see things in a whole different light...
Then it started again with gettng my ham-fist up to the connector. Oh well, all done now and all works AOK.
76F250High
May 15, 2023 11:40 AM
4x4falcon
Jan 1, 2013 06:02 PM
alconk
53
Apr 30, 2009 09:11 PM
strokersace
Mar 18, 2008 12:08 AM
DaveWilliams
13
Feb 1, 2007 05:35 PM
