Sponsored by: Auxito
Cabin heating problem
Old Dec 14, 2010 | 10:10 PM
steve(ill)'s Avatar
steve(ill)
--hot water goes into the top of the radiator, air blows over the coils, and cooler water comes out the bottom... lower hose should be cooler.
--if the radiator is plugged, why dont the motor overheat ?
---if the pump is bad and wont circulate water, why dont the motor overheat ?
---if the thermostat has failed, the gauge will not read in the "normal" range.
---if the heater core is partly plugged, you wont get any heat out of it
---if the blend door is broken, your mixing hot and cold air and mmight not get too warm.
Old Dec 14, 2010 | 10:29 PM
N7ghtwolf's Avatar
N7ghtwolf
Its not that the lower hose was "cooler", it wasn't hot... at all, not even warm. I could feel just a bit more warmth than the ambient temperature after running the truck for more than an hour. I believe I forgot to mention that there also wasn't any fluid running through it, I had the engine running and when I squeezed on the hose it collapsed without any resistance. I completely agree that its a weird occurrence that the motor wasn't overheating, but I'm positive that the water pump I removed is bad. I don't believe that the radiator is clogged, but for $120 its worth the piece of mind to go ahead and replace it while I've got it apart. Both heater hoses get hot so I don't believe that the heater core is the problem, unless like stated earlier its clogged and somehow the coolant its bypassing it and not fully heating the core.. I've also considered the blend door to be the problem. I kind of veered away from worrying about the cabin heating to worrying about why the lower hose didn't have fluid running through it as I'm going on a 1000 mile trip this Saturday.
Old Dec 15, 2010 | 07:32 AM
Justin's Green Truck's Avatar
Well, for your sake, I truly hope these things fix it. Let us know.
Old Dec 15, 2010 | 12:48 PM
N7ghtwolf's Avatar
N7ghtwolf
Put the new radiator in today and got it back together. I can now feel that theres fluid running through the lower radiator hose, so thats good. As far as the cabin heat I'm starting to lean towards the blend door, I remember seeing that someone on here has a step by step guide on how to remove the dash; but it will be at least a week before I attempt it.
Old Dec 15, 2010 | 07:23 PM
kmx12's Avatar
kmx12
Im having the same problem. My 98 f150 with 4.6 takes forever to put out heat. I blew out a freeze plug 2 weeks ago and it quit working for a couple days and slowly started working again. I back flushed the heater core and that helped a little. This last weekend I replace the water pump and it took 75 miles before it started puting out accetable heat. I do have a theory that its air trapped in the heater core. I make sure my overflow tank is overfull and tuesday I parked my truck on an incline with the front bumper 2 feet higher than the rear, it started working again last night and worked at 80 to 90% tonight. Last night was the first its worked since changing the water pump saturday. It seemed to do the same thing after the freeze plug was replaced.
Old Dec 15, 2010 | 08:09 PM
oldsnipe's Avatar
oldsnipe
Did you chech the thermostat to ensure that it opens properly before you installed it? I have gotten bad thermostats before.
Old Dec 15, 2010 | 09:00 PM
N7ghtwolf's Avatar
N7ghtwolf
Yes, I checked the thermostat before installing it.
I changed my mind, I'm going to replace the heater core and blend door tomorrow. I don't want to face this 17 hour journey without heat.
Old Dec 15, 2010 | 11:23 PM
Podaso's Avatar
Podaso
That's good you have circulation through the lower hose now. The heater core is a big project, let us know how it goes.
Old Dec 16, 2010 | 11:49 AM
N7ghtwolf's Avatar
N7ghtwolf
About to remove airbag, with me luck. I don't why this intimidates me but hellfire missiles don't.
Old Dec 16, 2010 | 01:06 PM
As long as you disconnect the battery and wait a few minutes before you unplug the air bag you should be fine. Then sit it on its back somewhere that way if it goes off it doesnt turn into a rocket. Some folks wear a grounding strap while they're handling air bags to eliminate static electricity. I never have but it's not a bad idea.
Old Dec 16, 2010 | 02:42 PM
N7ghtwolf's Avatar
N7ghtwolf
I cant get the plenum cover off, but i can see that the blend door is wide open
Old Dec 16, 2010 | 08:29 PM
N7ghtwolf's Avatar
N7ghtwolf
Blend door ending up being broke. I replaced it and the heater core and got it all put back together. I now have heat!
Old Dec 16, 2010 | 09:12 PM
  #28
Podaso's Avatar
Podaso
How long did it end up taking?
Old Dec 16, 2010 | 09:43 PM
  #29
N7ghtwolf's Avatar
N7ghtwolf
Around 7 hours.
Old Dec 16, 2010 | 10:15 PM
  #30
Podaso's Avatar
Podaso
So, after the fact, was your heater core plugged or was the cabin heating problem with the blend door...or a mixture of both?
