I 'll try to locate a picture, but that 2 wire bale bullet connector might be the IPR and if that is suspect then that my be the problem.....stand-by...that's military talk for "wait one minute"
Thanks, thats the plug to which I was talking about having the bad insulation, will it run with that unplugged? Going to go try to bandage the bare wires and hook up to see what that will do 4 me I'm slowly catching on to the acronyms any info what else to do to troubleshoot this thing greatly appreciated.
No it will either not run or run intermitantly - like a miss - Those two little wires are critical in the operating of the engine.....
Ya know with using that ether you are gonna be really pissed at yourself next time you try to pull the glow plugs and discover half of them are mushroomed and won't come out without pulling the head. NEVER for any reason use that garbage on a engine with glow plugs!
I think that IPR is your problem. You have to unplug it to get the filter housing off the engine. Something didn't go back together right. The engine will not run without it.
I checked all the glow plugs like read somewhere here by disconnecting plug and ohming outside pin on the 4 valve cover connectors all good. Band aid repair on plug bare wires and truck started up and ran. Thanks everybody for your help, I know need to maybe start new thread if can't locate one that can give me ideas on warm/hot starts being difficult, I have to give it half to full throttle in order to get her refired after shutting her down. Again thanks all.
Thanks again everybody for help. Went to local dealer they couldn't locate bale connector, the head diesel mech and parts guru told me to put 6E7Z-12A690-DA IPR connector repair kit on in its place, its a 2 side clip end. While there couldn't bring myself to pay $40. more than price of IPR Oring kit from dieselspecialist(13.67 vs 53.50) Also ordered fuel filter seal kit on ebay($23. vs $73.08 from dealer) so when get all here will tear into the old girl again. Not that I don't like yous guys but hope all goes well and don't have to ask a bunch of questions.
What did the Stealer charge you for the IPR connector Kit? And now I can confirm what I suspected that my truck has gone thru at least 1 IPR connecor, cause the latest one that I replaced was a side connector (plastic) that became brittle and broke...the new Bale type I just replaced I like better...Better fit and metal.
...also a lot of supporters here have great prices on O-Ring kits and the like, just remember to keep them in your thoughts...when your looking to buy.
connector was $12.12 tax and taters. I have been trying to use the classifieds section but haven't figured it out to well, could be because I'm not a full blown member but probably cus' I don't know what I'm doin. I would gladly buy from fellow FTE folks, maybe somebody can give me tips how to locate stuff over there.
